Evening all,
Apologies if this has been covered previously, but am wondering if anyone's noticed the same thing on their Tig :
Today I decided to just check out the light recovery points at front & rear on the Tig (MY 2011 TDi with no Towbar or anything unusual).
I popped the small front panel off (just to the inside of the Drivers side Headlight) and saw the threaded bolt hole that the recovery eyelet screws into. No problem.
So then I check the back and after popping the panel off (again, Drivers side on the plastic bumper) discover that it opens onto a black metal square-section tube and there's no threaded bolt hole to which to attach the recovery eyelet.
Can anyone tell me if they've had the same discovery on their Tig? Is it possible that this a part of the Towbar assembly (which I didn't order and certainly don't have the rest of as far as I can see) and it's covering up the actual threaded bolt hole? Or is it possible that the access panel is just on the incorrect side of the car and the threaded bolt hole is actually on the Passenger side?
Any experience would be appreciated!
