Results 1 to 10 of 15
Thread: Torx tool for Tiguan door trim?
    Sep 2012
    australia
    Torx tool for Tiguan door trim?(update with chrome button install guide)
    hi guys i recently bought a set of chrome buttons i want to retrofit on my tiguan but having issues finding
    the right tool to take out the door trims. been to bunnings and masters also repco but cant seem to find the
    right trox T30 screw driver because the bolts on the trim is recessed inside a grove. i just cant find a short
    enough L shaped driver to reach it. already did a few searches on the forum but the tools they use are too
    long to fit inside the grove. any ideas where i might pick 1 up?
    thanks in advance
    Sep 2012
    australia
    found a set at supercheap auto that fits in the grove.
    Adelaide hills, SA
    You can get Kincrome brand at Bunnings that's a very good value for money.
    Sent from my GT-N8000 using Tapatalk 2
    You'll have to post some pics of your buttons once they're installed.
    Sep 2012
    australia
    bought the supercheap set for $20. kinna expensive with me just needing the T30 oh well. will try the install this weekend hopefully i dont break anything
    Sep 2012
    australia
    i've installed the buttons this weekend. took awhile and some trial and error but managed to do it with out breaking anything. there is a rough guide out there to pull the trim off but i still find some things missing or could be done easier. so i'll write up a guide on how to pull out and install chrome buttons for 2012 tiguan below.
    NOTE: if you have a chinese friend try to get him/her to order the buttons and the accessories you want from a site called Taobao its 1/4 the price of ebay and aliexpress. some sellers just cover the chinese price in RMB straight into USD thats x7 the price. eg. you can buy a set of GTI stainless steel OEM pedals for $30AUD, 08-11 LED bi-xenon headlights for $100AUD, chrome window/side trims for $5-$30AUD just to name a few.
    The tools: a L shaped Torx T30 driver (make sure it has the torx screw head on both ends), a flat head screw driver and pliers.
    1) unscrew the Torx screws at the bottom of the door trim, cant miss it (its recessed) two for the front doors.
    2) use a flat head screw driver and insert it into a small grove on the front bottom side of your handle bar. pry the
    plastic strip open slightly (dont worry it wont damage the plastic) pull out the strip by hand top to bottom slowly.
    3) you will see 2 Torx screws inside the handle unscrew that with the long end of the screw driver (might need the pliers to help twist the screw lose).
    4)here comes the hard part. lift up the door trim panel to lose the top window grove of the trim. pulling the trim panel outwards on one of the corners its the easiest (need some brute force here to rip out the clip. see pic for clip locations).
    5) there might be some clips that's still embedded into the door. you'll need to pry it out with the pliers or screw driver, then re-attach it onto the door trim clip grove. Its a pain in the ass but trust me there is no way to re-clip the trim panel back onto the door if the clip remains.
    6)once you have the trim out disconnect the power window harness (you can leave the door handle cable on if you want).
    7)use the screw driver to push back the clips that are holding the button assembly.
    once you have the assembly out gently slot the screw driver into the side plastic of the button unit (make sure its in the middle so it un-clips both sides). while pushing the button out insert the screw driver into the other side of the plastic, now the button should pop out easily.
    9) put in the chrome button and slot back the assembly into the trim panel.
    10) clip back the power window harness. slot in the top window grove first that would hold the trim in place then push in the door clip. you should hear each popping sound when the clips are slotted into the door holes. screw the bolts in, push the handle strip back in and your done.
    NOTE Driver side door: just follow the guide from the start but there are more door clips and extra harnesses you need to pull out. once you have the assembly out there is 6 clips holding the button unit. you'll need to use the screw driver to loosen each clip from top to bottom in parallel sequences while pushing the button out (be gentle or you might break or crack the plastic assembly).
    NOTE rear passenger doors:
    there is only 1 screw holding the door trim at the bottom but still 2 in the hand rail. you dont need to take apart the whole door panel. just lift up and pull out the forward corner of the trim. 3 clips should come out.
    you should be able to access the button assembly with out taking it out. gently slot in your screw driver on each side to pull out and re-slot in the chrome buttons. this is much quicker, took 5mins.
    All up it took me around hour and half to do it all. the most painful bit is taking out the door panel and prying out the panel clips from the door.
    Erskineville, NSW
    torx or XZN/Triple-square?
