Page 11 of 11 FirstFirst ... 91011
Results 101 to 103 of 103
Thread: Tiguans and Rough Roads.
  1. #101
    Jul 2010
    Quote Originally Posted by Tiggy1 View Post
    I notice that the mirror adjustment knob seems rather loose and wondering whether there might be a backing nut that might have come undone (or wasn't tightened properly at the factory)?!
    No ... that's normal and is part of the design quirks (like bonnet lever on passenger side).
    Also the fact that the heater symbol is not in the right spot based on when you turn it on.
    Covered before in this thread:
    http://www.vwwatercooled.org.au/foru...ers-62651.html
    MY11 Tiguan 147TSI (SOLD)
  2. #102
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by aussietig View Post
    Ah, OK thanks - never had to use the heater (below 10Degrees is considered a cold-snap up here)
    Strange how VW makes most other things so well, then throws in the odd crappy bit like that (another quirk as you say).
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  3. #103
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by MGV View Post
    Hi Tiggy1, sounds just like what i had, i tried products on all the rubbers which did nothing, but at my 30000k service they applied a lubricating paste (expensive!) to the door latch/catches which completely resolved the noise. It's kind of like a white-ish drier feeling grease that is still there & working 10000k's later.
    Hi MGV,
    good idea - sounds like stuff Dad used to use (aircraft mechanic) called "Dri-Lube". I think he might have a stick of it lying around at home so might give it a go.
