Little update, I received D1S bulbs from the Ebay seller even though I asked them to send me a set of D3S.
So I went to a local aftermarket shop and bought a D3S bulb set for 119AUD. They are same Phillips Eco Start as my original bulbs but have 6000K color temperature. Tried to installed them surprise there is a small tab inside the bulb connector which makes it difficult to plug in the power connector. But still can push it in with little force and bulbs work ok.
Now there are few problems, 6000K color temp are not matching with DRL leds. LEDs are bit on yellower side where as xenons are on bluer sideAnd the biggest problem is these Xenons are weaker than OEM ones. And with little research I got to know that most of these Phillips Xenons are counterfeit stuff from China.
So I then placed an order for Philips X-treme Vision D3S bulbs from powerbulbs.com and hopefully they are much brighter than these counterfeit xenons.
