Results 1 to 10 of 19
Thread: Tiguan Xenons/HID replacement
    Jun 2013
    So one of my Tigs Xenon lights started to playing up. I have to switch off and on again to get the light working again , it is the right hand lower beam light. After about 5 mins it goes off again giving a bulb out warning.
    Does someone knows the type of these Xenons, I saw D1S and D3S bulb verities are there, but not sure which one. And any DIY or instructions for replacement is much appreciated!
    Also are these the correct ones
    Genuine Philips D1S R C HID Xenon 8000K Bulbs Volkswagen VW Golf Jetta Tiguan | eBay
    Tiguan Xenons/HID replacement-$_12-jpg
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Sep 2010
    QLD
    Your best bet is to take off the cover and photograph the label behind the bulb. Should tell you the model.
    I doubt it's a D3S as it's a newer bulb type but then your Tiguan is the FL model. D1S will be the norm, and cheaper too.
    I would advise against anything over 5000k, may look brighter but not really.
    Stick with Phillips or Osram.
    If you want more performance, go for Philip Extreme Vision or Osram Cool Blue Intense.
    Have heard good thing about Osram CBI, this bulb appear to be the OEM for late model Merc (to match their DRL colour).
    You may want to replace both bulbs though, for performance and aesthetic reason.
    There is one cable connector for each bulb, you need to detach that first. After that, it should be as simple as twist and pull. Failing that, consult the manual or dealer. Xenon bulb rarely fails this early. Perhaps a warranty claim?
    2011 Tiguan 125TSI - SOLD
    2014 Race Blue Octavia RS 162TSI Combi
    Check out my leather work ----> http://pedsnro.blogspot.com/
    Jun 2013
    Quote Originally Posted by 99Reza View Post
    Thanks a lot for your info mate. After reading your comment I decided to give it a go in the evening. It is D3S type bulb. I took few pics and then couldn't resist to try and take it out. So after few minutes if struggling I managed to take it out. Bulb looks ok except small white patch on a side of the glass. Then I put it back and switched it on, to my surprise it lighted up! haha.. But I am sure I will have to replace it anyway.
    I will post some pics here, if anyone wanted to know same info in the future..
    Sep 2010
    QLD
    Glad you worked out the bulb type. Probably just a loose cable
    It's the same type as the one on the mk3 Octavia RS.
    AFAIK there's only one higher performance bulb for D3S, it's Philip Extreme Vision and they are far from cheap, about $300 a pair.
    Question, do you find the xenon light on your Tiguan bright enough? Seeing both cars share the same bulb type.
    I found the light intensity on the Octavia is vastly inferior to the pre-facelifted Tiguan one, even my 7 year old C-class still has the upper hand in terms of light intensity. I'm guessing inferior bulb as the headlight has a very good spread (decent projector) just lacking intensity.
    Anyhow, this is the bulb on the Octavia for comparison. Sorry for the upside down photo.
    Tiguan Xenons/HID replacement-20140730_173501-jpg
    Jun 2013
    Jun 2013
    Thanks for the pic, Yeah to me bulb intensity is weaker given that they are Xenons/HID in my MY13 tiguan. I think bulbs are very similar between Octavia and face lifted Tiguan 35W Philips Xenstart vs XenEcostart
    So will it be possible to interchange D3S bulb with a D1S. Because of my lack of patience I already ordered a pair from above link early in the morning ..
    Jun 2013
    Looks like they D1S/D3S are not interchangeable. Hope seller agree to send me a correct set at least
    Dec 2008
    Alexandra, New Zealand
    I thought the low beam (the one you say is playing up) is a standard halogen H7 bulb ??
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Jun 2013
    Quote Originally Posted by NZTiguan View Post
    Nope .. That is high beam I think. All the motors for adjusting xenons for dynamic cornering, tilt adjustment etc connected with low beam xenon lights, which we use mostly.
    Sep 2010
    QLD
    Quote Originally Posted by Ramee View Post
    Ouch, hopefully that works out with the seller.
    Thanks for the detailed picture, will be a good reference for someone with similar situation.
    Thanks for the feedback as well, looks like the headlight can do with an upgraded bulb. I will let you know once i've gotten my hand on the higher performance bulb, see if it's worth the $300 bucks.
