Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Tiguan Xenon Retrofit Part Numbers
    Nov 2015
    Fremantle, WA
    Hi all,
    Planning a xenon retrofit and having trouble making sense of the multitude of part numbers for the headlights themselves.
    I've found the following numbers should fit the Tig Mk2, with the latter seeming to be an updated part number or something.
    5N1941752 5N1941753
    5N2941753 5N2941754
    5N1941034 5N1941044
    I assume there is a left hand drive and RHD version, but don't know how to differentiate. Anything else to consider?
    Recently picked up my 2012 155TSI and just booked in for the APR tune. Loving it.
    Yes there will certainly be different part numbers for LHD and RHD versions as the cut-off will be different on the drivers vs. passenger side.
    This topic has been discussed a few times so rather than repeat it I'd suggest having a read through of the bi-xenon thread: Bi-Xenon Headlights for Tiguan - Retrofitting
    Jan 2011
    Brisbane - QLD
    and you will need a lot of other parts to make them work properly. it is not a simple plug and play with just the headlights.
    you need uprated cecm (if the stock one does not come with high beam shutter pins), AFS module, wiring, sensors (front and back for awd), adapter from halogen 10 pins to bixenon 12 pins plugs, etc etc... and proper vagcom coding.
    overall it would cost $3k back in the day when aud was in a much better position (if buying from overseas).
    MINI Cooper S Clubman - FWD
    Yes and the auto-levellers and washer unit to be 100% legal.
    The far cheaper (and legal) option is to get some higher output (Phillips/Osram) aftermarket halogen bulbs.
    Nov 2015
    Fremantle, WA
    Thanks tigger, yeah I've read through every thread I can find, can't find any mention of what the individual part number mean though. I assume lights that were destined for other RHD countries should be suitable.
    Yeah I hear you nat, don't mind the outlay, halogens are **** in the country.
    Nov 2015
    Fremantle, WA
    Bugger no swearing
    Jan 2011
    Brisbane - QLD
    if i were you, i would just use the best H7 bulbs available:
    Car Bulbs › H7 (499) | PowerBulbs
    and then fit a led light bar with a licence plate mount. easy to fit and easy to remove.
    Driving Light Number Plate Mounting Bracket, Great Whites GWA0001
    X Bar - Universal Light Mounting System
    these combo will give you much better brightness for country driving (provided no oncoming cars present). i had CATZ spot lights mounted on a nudge bar in the past with 110w H1 bulbs on my Rav4 and they just turned night into day (plus fog lights and high beam 90/110w H4 bulbs all turned on)
    Nov 2015
    Fremantle, WA
    Thanks nat, yeah I'll definitely consider it. That number plate bracket is nice and minimal.
    Mar 2015
    Torrens ACT
    Take a look at fitting and looming carefully a couple of high quality Rigid Industry 6 inchLED light bars behind the grill as per photo.
    Far far, far and away much better than Xenons which, by the way, are fitted to my other cars (along with light bars).
    Brilliant light output which goes almost forever (hyper spots) and is loomed, via relay into main beam.
    All up with professional fitting, including made to order brackets, less than a $1000, no coding, adjustable, far better light output = no brainer.
    I put a similar set up on my Audi SQ5 as the Xenons are just not as good as folk think on high beam.
    Dingah
    Attached Thumbnails Attached Thumbnails Tiguan Xenon Retrofit Part Numbers-img_0255-jpg   Tiguan Xenon Retrofit Part Numbers-img_0254-jpg
    That's a very neat looking job Dingah. Tiguan Xenon Retrofit Part Numbers
