Thanks Tig.
Came up better than I hoped.
Awesome light output from the SR2s with very defined beam patterns.
You only get flahsed the once!
Happy Xmas.
Dingah
Again, pardon my ignorance, but would these work?
Volkswagen HID Xenon KIT EOS Passat Tiguan Touareg Touran ALL Models NO Error | eBay
Doesn't say how many lumens they are, would I expect brighter than 1500? Do they just plug in and mount that box to whatever with self tappers?
using HID bulbs and retrofitting them in headlights specifically designed for halogen bulbs are not only illegal but stupidly annoying and inconsiderate to other drivers (glare to oncoming drivers and glare on their rearview mirrors).
the beam is smeared everywhere and they don't have clear beam cut off like proper HID headlights.
I hate these type of drivers with passion. usually they are fitted to tradie 4x4, Camry, Jazz, etc. they just have no educated knowledge and consideration to other public road users. perhaps they are simply just ignorant. they should just get aftermarket headlights with proper beam cut off at minimum, that way their lights won't blind others.
MINI Cooper S Clubman - FWD
Then go the LED light bar route and give up on the flawed notion of retro fitted xenons.
The end result is legal, provides superior output and is a darn sight cheaper.
All work carried out by Tuggeranong Auto electrics who are likely the most professional auto electricians I have ever used.
I only live the other side of Mount Taylor from you so come over one evening and I'll show you the set up on the SQ5 and the wife's R-Line Tig and it will explain everything.
Dingah
Hi all. Digging up my thread for an update.
Went the light bar route, set it up so its removable when not in use. Very happy with the outcome.
On another note, I really like the led headlight assembly, and had the idea of buying one of the aftermarket headlight assemblies, and installing halogens in it instead of the xenons. Also may be possible with OEM housings.
AUTO PRO 2013 15 For vw tiguan headlights car styling Q5 bi xenon lens LED DRL14 High brightness led xenon H7 led parking-in Lights & Indicators from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
What do you think? purely aesthetic but allows for an updated look without having to worry about legality, or blinding other drivers.
If you look around enough, you might find ones that have the LED DRLS but are also halogen from manufacture: no need to do any modification. However, again, there are ADRs that cover DRLs. They are only supposed to be on while the headlights are not. They can only stay on with headlights if they dim and perform the function of parkers. Also, make sure you get headlights correctly set up for right hand drive cars so they have the correct shielding in place.
Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
The HID's aren't built into the aftermarket housings, they just usually come with a set of bulbs and ballasts and you install them yourself.
