I just did a quick comparison on ECS. They look to be different. But double check for youself.
I am wondering whether Tiguan and Golf Mk6 share same lower control arm. I am asking this because there is a group buy going on to get these from super pro supplier and super pro does not mention their lower control arm compatible for Tigs. Can any one confirm these are interchangeable. I know HP's Big turbo Tiguan have these but they are specially custom made units for Tiguan.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
The arm part is similar, the rear bearing support is totally different, so you can not use them on a Tiguan.
We make a kit in conjunction with Superpro and we have an exchange rear hanger & they are available through your APR dealer.
They were tested & developed on our own project Tiguan.
We will also release our own Tiguan specific sway bars in the following weeks - these have the correct clearance at all points & also have proper mounting stops & anti noise sway bar link end mounts.
I should also mention we have had Volkswagen Racing UK build us Tiguan specific coilovers. these are dampened & sprung specifically for the Tiguan & are not "one fits all" application.
Thanks Guy for the clarification. So I do not need to worry about group buy
I am interested about sway bar for front and also may get the engine swing arm mount at the same time.
