Results 1 to 10 of 97
Thread: Tiguan VCDS Coding Options
    Jul 2010
    Various Rear Wiper settings
    Tiguan VCDS Coding Options-9-central-electronics-rear-wiper-jpg
    Disable additional licence plate bulb monitoring @ Bit 6
    Note: Will get rid of the stubborn "bulb out warning light" received even with error-free LED bulbs
    Tiguan VCDS Coding Options-9-central-electronics-byte-23-cold-lamp-monitoring-jpg
    Disable footwell light monitoring @ Bit 3
    Note: Will not trigger "bulb out warning light" when fitting normal LED bulbs
    Tiguan VCDS Coding Options-9-central-electronics-byte25-jpg
    Other worthy modules to note:
    MODULE 10 - Park/Steer Assist: Adjustment options for Parking Sensors (e.g. volume & frequency/pitch of the beeping sound)
    Note: Need to click on 'Adaptation' button to access below screen
    Tiguan VCDS Coding Options-10-park-steer-assist-adaptation-jpg
    MODULE 16 - Steering Wheel: Enabling flappy paddles on steering wheel @ Bit 4
    Note: Usually requires a Mk6 Golf R or GTI MFSW
    Tiguan VCDS Coding Options-sw-coding-4-jpg
    MODULE 17 - Instruments: Disabling Seat Belt Warning @ Bit 1
    MODULE 19 - CAN Gateway: Need to manually enable Module 37 - Navigation (when installing RNS510 for the first time) @ Bit 6
    Note: This will get rid of fault code within Module 19
    Tiguan VCDS Coding Options-19-can-gateway-enable-37-navigation-jpg
    MODULE 37 - Navigation: Changing colour scheme of RNS510 Display @ Bits 4-5
    Tiguan VCDS Coding Options-37-navigation-jpg
    VCDS CODING FOR RVC RETROFIT:
    MODULE 37 - Navigation: To enable and show RVC on display @ Byte 3, Bit 6
    Note: This only works for the low line camera (i.e. without the control module that gives you moving guidance lines)
    Tiguan VCDS Coding Options-37-navigation-enable-rvc-jpg
    Tiguan VCDS Coding Options-37-navigation-microphone-off-jpg
    MODULE 10 - Park/Steer Assist: To also show OPS (on LHS) together with RVC. Also tick this extra box @ Byte 0, Bit 5
    Tiguan VCDS Coding Options-10-park-steer-assist-rvc-ops-enabled-jpg
    NOTE: MORE TWEAKS LISTED IN POST #18
    MY11 Tiguan 147TSI (SOLD)
    Adelaide hills, SA
    I'd just like to add that, before you start any tweaking in VCDS do the full system scan, so you have all the controllers original coding when the things go bad, there is no undo button.
    Before you change coding many screens in VCDS have "Test" button and it will display "Coding accepted" when all good, if not don't click "Save" button.
    May 2009
    Perth, WA
    Great work aussietig, very useful thread.
    MY11 Golf R - Rising Blue - 5DR - DSG - 19" Black OZ Ultralegerra - Leather - Sunroof - MDI - Euro Plates - Milltek Exhaust - Bluefin - SOLD
    MY11 Tiguan 147 TSI - DSG - Pepper Grey - Black Leather - RVC - MDI - BT
    Jul 2010
    Bungendore
    Quote Originally Posted by Prodigy View Post
    Here, here. Am I right in assuming that if you activate the 'mirror lowering with reverse gear' that they will lower? I wouldn't have to change anything else? If so, that is a massive WIN!
    MY10 Tiguan 125TSI | Pearl Black | Manual | Comfort Pack | Kamei Eyelids | MDI | Not Leather | Rubber Floor Mats | Kids | Random Spillage | VWWatercooled Sticker | APR stage I | H & R springs | ECB nudge bar
    Oct 2009
    Quote Originally Posted by Captain Bungers View Post
    Getting that mirror to lower is totally worth the price of the cable!! (But would prefer to borrow someone elses...)
    Jul 2010
    Quote Originally Posted by ChrisJ View Post
    For me, it was ability to enable the flappy paddles that cable has paid for itself somewhat.
    But more so ... the peace of mind that there's no problems with the car under a full scan.
    Or a heads up on what's the problem when things do go pear shaped.
    Nov 2010
    QLD
    Hey all,
    Has anyone with a MY11 Tig been able to get Side mirror dip to work when in reverse?
    I can get the option to appear in MFD using VCDS but nothing happens to mirror when in reverse?
    2011 Tiguan | 147TSI | Deep Pearl Black | Corn Silk Leather | Panoramic Sunroof | DSG (7-speed) | 4Motion | Bluetooth | MDI | Reverse Camera | RNS510 | 18" New York wheels | Premium Floor & Boot Mats | VCDS Micro CAN
    Adelaide hills, SA
    Many around the world already tried that, it didn't work. In Touareg you have to have el.seats with the memory.
    Oct 2009
    Damn...still cranky the leather seat option has an electric seat but no memory...not getting the mirror to dip cause of that makes it worse...
    Jul 2010
    Looks like the Oracle @ Ross-Tech also backs up the story of our Oracle here:
    TDIClub Forums - View Single Post - Looking to turn off horn when locking car. Need some help.
    So a pointless tweak on our Tigs here!
