Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 97
Thread: Tiguan VCDS Coding Options
  1. #61
    Quote Originally Posted by Ramee View Post
    Works on mine!! Thanks a lot guys
    Tigger, instructions in above picture works on mine.
    Winner!!!!
    Do you mind sharing the part# of your cluster?
    Sent from my iPhone using Tapatalk - now Free
    Jul 2010
    That's interesting.
    My cluster has part# 5N0 920 872 whereas yours is part# 5N0 920 973 B.
    Is from your 2010 Tig?
    I think this just confirms MY11 Tig (without revision B cluster) can't get it.
    MY11 Tiguan 147TSI (SOLD)
  3. #63
    Aug 2012
    Warrnambool, Vic
    Hi All,
    I have a 2014 Tiguan Track and Style and I am sick to death of the 120km/h speed warning coming on all the time. Once it is on, it blocks the MFD. I have disabled the speed warning using the steering wheel buttons but that has done nothing. I have searched through the system with my Ross-tech VCDS but can't find where to disable it. I am living in Qatar for a while and the speed limit is 120 but just about everyone travels quite a bit higher than that. Cheers.
    MY 13 Golf R. APR Stage 1. +DSG software upgrade.
    2013 Passat Alltrack 130 TDI
  4. #64
    Adelaide hills, SA
    Did you also disabled it in the MFD using the steering wheel?
  5. #65
    Feb 2013
    Perth, WA
    I've heard of some countries having it coded and locked out. There still should be a VCDS option but I can't seem to find anything that supports that on the RossTech wiki.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  6. #66
    Aug 2012
    Warrnambool, Vic
    Yep, I did disable it with the MFD but to no avail. Thanks Transporter.
  7. #67
    Feb 2013
    Perth, WA
    Try setting the speed warning on the MFD to something like 180 and see if the MFD being set overrides the hard set speed limit.
  8. #68
    Mackay QLD
    Quote Originally Posted by prrow61 View Post
    Hi All,
    Any chance you can post an autoscan of your module 17 Instrument panel I recall a specific coding for Saudi Arabia? spec try changing it to the rest of the world (RoW) like the below
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5N0 920 873 A HW: 5N0 920 873 A
    Component: KOMBI H05 0705
    Serial number: 00000000000000
    Coding: 111F00
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 3147D85A60DCE2909F5
    No fault code found.
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
  9. #69
    Throttle Body Alignment Procedure
    Just thought I'd add this procedure here for completeness...
    Seems to be a recommended whenever disconnecting the battery/ECU to run this short procedure from Ross-Tech:
    Turn the key on but do not start the car.
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    Group 060
    [Go!]
    It should say "Basic Settings: OFF" on the top of your screen.
    Click [ON/OFF/Next] to turn on Basic Settings.
    It should now say "Basic Settings: ON" on the top of your screen. Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
    Click [ON/OFF/Next] to turn off Basic Settings.
    It should now say "Basic Settings: OFF" on the top of your screen
    Click the [Done, Go Back] button and you're all set.
    Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
    Dec 2013
    UK
    VCD for Auto folding mirrors on lock
    Hi
    Is their any VCDs tweaks available to enable autofolding of mirror when car is locked with the key? I have a mirror pack but could not auto fold mirror by keys
    Thanks
    [Select]
    [01 - Engine]
    Group 060
    [Go!]
