Winner!!!!
Do you mind sharing the part# of your cluster?
Sent from my iPhone using Tapatalk - now Free
Hi All,
I have a 2014 Tiguan Track and Style and I am sick to death of the 120km/h speed warning coming on all the time. Once it is on, it blocks the MFD. I have disabled the speed warning using the steering wheel buttons but that has done nothing. I have searched through the system with my Ross-tech VCDS but can't find where to disable it. I am living in Qatar for a while and the speed limit is 120 but just about everyone travels quite a bit higher than that. Cheers.
MY 13 Golf R. APR Stage 1. +DSG software upgrade.
2013 Passat Alltrack 130 TDI
Did you also disabled it in the MFD using the steering wheel?
I've heard of some countries having it coded and locked out. There still should be a VCDS option but I can't seem to find anything that supports that on the RossTech wiki.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
Yep, I did disable it with the MFD but to no avail. Thanks Transporter.
Try setting the speed warning on the MFD to something like 180 and see if the MFD being set overrides the hard set speed limit.
Any chance you can post an autoscan of your module 17 Instrument panel I recall a specific coding for Saudi Arabia? spec try changing it to the rest of the world (RoW) like the below
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 873 A HW: 5N0 920 873 A
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 111F00
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 3147D85A60DCE2909F5
No fault code found.
MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
Just thought I'd add this procedure here for completeness...
Seems to be a recommended whenever disconnecting the battery/ECU to run this short procedure from Ross-Tech:
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
It should say "Basic Settings: OFF" on the top of your screen.
Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen. Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
Click the [Done, Go Back] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
