Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 97
Thread: Tiguan VCDS Coding Options
  1. #41
    Jul 2010
    Good consolidation sticky Ryan_R.
    But I thought there was a link to modified FW 3970 in the forum somewhere.
    You've only got the link to FW 3810.
    Let me know if you can't find it!
    MY11 Tiguan 147TSI (SOLD)
  2. #42
    Apr 2010
    It is in fact 3970, just had a different number from the MyGTI website stuck in my head
  3. #43
    Jul 2010
    There's a slight chance I've just named it wrong
    Is there a file inside the ISO that would confirm the version?
    Yes AFAIK ... should be text file in the root directory called VERSION.
  4. #44
    Jul 2010
    Just added coding required for RVC retrofit.
    Refer to post #2 of Page 1 for details.
  5. #45
    Mackay QLD
    Hi I have been asked to tweak a 2010 TIguan with the white MFD and was wondering which Byte/bit adaption? I need to activate the static cornering light function via the high beam?
    In the old red MFD models with a separate module 46, this option was available in a drop down menu in module "09 Central Electronics" "Byte 23" "Bit 3-4" that gives you 00 Turn Lights not active, 08 Turn Lights Via Fog Lights, 10 Turn Lights via High Beam and 18 Turn lights via Xenon Shutter.
    Secondly has anyone managed to activate the auto closing of the windows in the new 09 module? In the 08 09 Tiguans that had the old 46 module that had 19 bytes it was activated at Byte 6 bit 6.
  6. #46
    Mackay QLD
    Over the holidays,I enabled the rain closing function in the new Tig in Module 19 and the sub RLS module and tested the closing function and all went well. However I am unable to disable the function permanently using the buttons on the steering wheel & MFD. I removed the keys from the ignition and when I rechecked the convenience menu the function had re activated itself. Tried it again with the wiper stalk set to off position and still no luck. Anybody out there with the same problem?
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
  7. #47
    Apr 2010
    There are two RLS settings in VCDS, you might need to disable one of them. Why do you want it turned off?
  8. #48
    Mackay QLD
    Just wanted to check that I could switch it on & off using the MFD option just as you would switch on & off the other options available in the convenience & lights & vision sub menus.
    What are the 2 RLS settings? I activated bits 5 & 6 in byte 4 and another bit in one of the bytes in the RLS sub module selectable from the BCM 19 module main page.
    Mods: VCDS tweaks |
  9. #49
    Apr 2010
    iirc one tickbox adds the option to the MFD and the other turns it on - perhaps you have to undo the 2nd one???
  10. #50
    Mackay QLD
    Good day all
    Came across this while trawling through the Vortex VCDS Forum looking for Tig autoscans and found this courtsey of "Tim S" May come in handy if someone accidentally plays with Byte 18 in their #9 BCM module
    Here are all of the Tiguan values for Byte 18:
    2F | VW Tiguan (VW316) | Halogen/Xenon | RoW | TFL_0
    30 | VW Tiguan (VW316) | Halogen/Xenon | RoW | TFL_S
    50 | VW Tiguan (VW316) | Halogen/Xenon | NAR | TFL_1
    51 | VW Tiguan (VW316) | Halogen/Xenon | NAR | TFL_S
    8A | VW Tiguan (VW316/416) | Halogen/Xenon | RoW/Ska | TFL_1_Ska
    TFL_0: TFL mit NSL u. RFL (daytime running lights and rear fog light, reversing light)
    TFL_1: mit TFL TFL-Outputs (daytime running lights with daytime running light outputs)
    TFL_S: TFL Skandinavien Abblendlicht m (daytime running lights via Scandinavia low beam lights)
    Mods: VCDS tweaks |
