Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 97
Thread: Tiguan VCDS Coding Options
    Nov 2010
    QLD
    Sorry, just realized that others have noted the problem with the "dip side mirror" coding.
    //- On a side note... I enabled the "Beep on locking" code which added the option "ATA Confirmation" to my convenience menu however did not add any horn noise when locking the car so I went back not VCDS to disable that one bit, confirmed the code string was 100% matching my initial scan of module 9 however the "ATA Confirmation" option is still in the menu (only difference is you cant turn it on or off)
    Seems strange to me that it is doing this, any suggestions? If it's not going to work, I'd rather the option not be there. -// note: I was able to get rid of the stuck ATA menu item buy just leaving the car for 20mins
    For the people who have this working, do you have the optional security system? (I don't, perhaps that's the problem!?)
    Cheers,
    Supervisa
    2011 Tiguan | 147TSI | Deep Pearl Black | Corn Silk Leather | Panoramic Sunroof | DSG (7-speed) | 4Motion | Bluetooth | MDI | Reverse Camera | RNS510 | 18" New York wheels | Premium Floor & Boot Mats | VCDS Micro CAN
    Jul 2010
    Quote Originally Posted by Superviza View Post
    Yes mate ... you do actually need to have taken out the factory "alarm" option for the beep to work.
    I've noticed most people don't tick that box!
    From memory, it's a $600 option and gives you motion sensors and siren.
    Admittedly, VCDS coding description is a bit misleading!
    Actually "beep" sound comes from the siren and NOT the horn from your steering wheel.
    MY11 Tiguan 147TSI (SOLD)
    Adelaide hills, SA
    Quote Originally Posted by ChrisJ View Post
    Getting that mirror to lower is totally worth the price of the cable!! (But would prefer to borrow someone elses...)
    Many around the world already tried that, it didn't work. In Touareg you have to have el.seats with the memory.
    Oct 2009
    Damn...still cranky the leather seat option has an electric seat but no memory...not getting the mirror to dip cause of that makes it worse...
    Jul 2010
    Have updated original posts with a few more tweaks & screen prints
    Jul 2010
    Looks like the Oracle @ Ross-Tech also backs up the story of our Oracle here:
    TDIClub Forums - View Single Post - Looking to turn off horn when locking car. Need some help.
    So a pointless tweak on our Tigs here!
    May 2009
    Perth, WA
    Thanks to aussietig and this thread today i activated my Driving Light DRL's, adjusted the number of comfort blinks and rear sensors volume/frequency, also activated the dipping passenger mirror option, damn shame it doesn't work though.
    MY11 Golf R - Rising Blue - 5DR - DSG - 19" Black OZ Ultralegerra - Leather - Sunroof - MDI - Euro Plates - Milltek Exhaust - Bluefin - SOLD
    MY11 Tiguan 147 TSI - DSG - Pepper Grey - Black Leather - RVC - MDI - BT
    Jul 2010
    Have had some success enabling a few more items on my MFD:
    Tiguan VCDS Coding Options-mfd-coming-home-lights-1-jpg Tiguan VCDS Coding Options-mfd-rain-closing-1-jpg
    Some updates and further tweaks in MODULE 9 - Central Electronics
    Ticking Bit 5 & 6 will give you auto close when raining and selectable option in MFD @ Byte 4
    Tiguan VCDS Coding Options-9-central-electronics-rain-sensor-auto-close-jpg
    Enabling Fogs as DRL now made easier with Bit 1 labelled accordingly @ Byte 14
    Note: This will enable Park Lights as DRLs also
    Tiguan VCDS Coding Options-9-central-electronics-drl-fogs-only-active-jpg
    Ticking Bit 6 will give you just Park Lights as DRL @ Byte 15
    Tiguan VCDS Coding Options-9-central-electronics-drl-parkers-only-active-jpg
    Can dim brightness of DRLs (low beam and fogs only) by changing Dec1 value @ Byte 24
    Note: 100 is maximum brightness. Park lights don't dim
    Tiguan VCDS Coding Options-9-central-electronics-dim-drl-jpg
    Nov 2008
    QLD
    legend aussietig!
    Apr 2010
    There's a similar thread in the Mk6 Golf section that might also have some application for the Tiguan:
    http://www.vwwatercooled.org.au/f112...ary-50749.html
