Results 31 to 36 of 36
Thread: Tiguan VAR Design Downpipe
  1. #31
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by glidn View Post
    So any more progress on this? any resolution yet found from your current tuner?
    No resolution (as yet) I'm afraid. Insurance paperwork has been taking a while to go through it seems. Simon from Viezu has said that he wants to have another go at loading tune file using different connection though - hoping to tee something up with him to try in next few weeks, so will let you know how it goes.
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  2. #32
    Dec 2009
    Canberra
  3. #33
    No experience with these specifically, however if you're going to replace the DP then most of the tuners recommend going to a 3" DP as best option for power increase vs. noise generated.
    The 2.5" is quieter but you won't have as big a power gain as with a 3" system.
    There's not a lot of benefit in going bigger (i.e. 3.5") unless you're going to put a significantly bigger turbo on and then it's going to be a noisy system.
    If you can't find a 3" system locally for the Tiguan (Simon at Viezu should be able to help you out here), then I suggest that you buy a Golf R downpipe and take it to an exhaust shop and get them to modify it to fit.
    Sep 2011
    Townsville, Nth Qld
    Success at last! After many months and an extreme amount of patience (both from me and Simon at Viezu), my Tig has it's new ECU and they have finally sorted out the tuning/hesitation issue
    Simon got the new file during the week and immediately organised to come down and put it on (4-1/2hr trip each way mind you). We were both elated (that hesitation issue was resolved) and a little disappointed at first, given that it didn't have the punch straight up we were both expecting/hoping for. Is certainly quick, and very smooth but the adaption period will tell the tale as to how good it is over next few weeks
    Simon's new TCU (transmission control unit) tuning device that he also put on is a perfect addition and makes the gear changes smooth as silk and better able to handle the extra power/torque. It is only a test unit but once he has done some more trials I believe he is going to officially release them.
  5. #35
    hi guys
    Yes lots to update on Tigs in terms of new mapping options and I am in talks with a new transmissions tuning brand too which will compliment the Viezu ECU tune side of things.
    The new maps on the tigs are strong but smooth - and linear - even the hardcore race files. They are also taking a good few hundred KM to fully go through adaption - Tiggy1's Tig was much faster after even only about 20km of driving so plenty more to come out of it.
    Will keep everyone up to date
    Please email any questions as I hardly get time to come on the forums much !
    Simon
    simon@viezu.com.au
    http://viezu.com.au/ VAR Design. Exclusive Viezu distributors and developers for Oceania.
    Some of the best locally developed VAG tuning options on the market now released for ECU and DSG along with some of the best quality and value exhaust ranges /CAI's in Oceania. Put us to the test - 100% satisfaction money back guarantees.
  6. #36
    Don't go 2.5 inch on the DP - it's just too small and completely pointless IMHO.
    2.75 is ok, 3" is perfect. (even for bigger turbo set ups, although there can be benefit in going larger if you've got a huge turbo and don't mind more noise - which with 600hp you probably won't ...)
    Catback is different - 2.5 is fine for stock turbo depending on its flow rate characteristics. Bigger turbo and you're into 2.75 being ideal at the least or a really big turbo you want a very good 2.75 or 3.0.
    Noise is marginally increased at a cruise but give a more fruity note at WOT.
    Hope that helps
