Personally I'd never go past the S3 kit (Not stage 3) on the Tiguan. K04 Turbo with exhaust, FMIC and intake will see you at about 250kw/450NM which will do me just fine.
I would probably actually stop performance upgrades at the intake and ECU stage though. I have ordered a Carbonio intake in ....
Doing cosmetics now only. Radio, sunglass holder, suspension, wheels, crossdrilled brake discs etc coming up shortly ....
EDIT: and a downpipe & cat if it ever becomes available
Wheels, intake, full turboback and stage 2 ECU are where I'm pretty sure I will stop. This will likely take me at least a full year or more to acquire, assuming the turboback even becomes available. Should have the intake as a christmas present.![]()
Tiguan 2.0T 4Motion - APR Stage 1
S3 kit is the Stage 2+ from my list above. Its the K04 turbo upgrade kit with bits as found on the Audi S3. Good for 240-250kw.
http://www.goapr.com.au/products/new_turbo_k04.html
For the use I have for the Tig this is the most I'd need. I'm reserving big upgrades for the Golf R coming.
Mmmmm, .... just had a thought, the R will have all the S3 bits I need for the Tig on it (if it will fit) and then I only need to buy 1 x Stage 3 kit for the R .....![]()
just found it!
Good grief- who's responsible for this deeply hidden link:
APR Turbo Upgrade Packages
APR Stage III/III+ Kits - 1.8T Transverse
Golf/ Polo GTI / Beetle / Passat 1.8T K04 Turbo Upgrade
VW GTI/Jetta/Eos 2.0TFSI S3 K04 Turbo Upgrade
VWGTI/Jetta/Eos 2.0TFSI Stage III Upgrade
They obviously don't want to sell any to Tig/Mk6 Golf owners because the first thing you read as you scan thru the headings is Stage III/III+ Kits - 1.8 Transverse!
