Page 12 of 20 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 198
Thread: Tiguan Tuning Starts !
  1. #111
    Jul 2007
    Canberra
    I think Clipper has a manual?
    I will make you an intake John, standard price;
    "1 million dollars!!"
    Forever blowing bubbles.
  2. #112
    Nov 2008
    QLD
    Quote Originally Posted by Pullstarter View Post
    done! I'll even throw in a carton!
  3. #113
    Nov 2007
    Been testing the pod filter I'm running atm. Am concerned about the intake temps. After 30mins drive air temps surrounding the pod is at 50d egrees c ....... Outside temp is 32 degrees.
    Not too confident the pod is actually helping at all apart from a deeper intake noise and more audible diverter valve operation.....
    Sealed CAIs such as the Carbonio or Modshack ones seem the only way to go I'm afraid .....
    Have you measured temps at the filter yet Simon ?
  4. #114
    Jul 2007
    Canberra
    No I haven't Johan but i suspect it's fairly cool. Have you mounted it right behind the headlight? Seems to be quite a lot cooler there than behind the factory grille intake.
    I noticed a slightly faster throttle response with the pod (mine is also sealed remember) but not really what you'd call a power increase. I was mainly after DV noise anyway
  5. #115
    Sep 2009
    Perth
    just a few questions, with the chip does it cause any lag?
    at what rpm does power kick in (or you have to slam on the accelerator hard)?
    is it still responsive?
    (refering to automatic BTW)
    does the chip tweak any boost setting? my understanding is before increasing boost its ideal to replace intercooler air filter and exhaust.
    what are factory boost set on?
    what is boost set to after chipped?
    GTI engine internals are recommended to what horsepower before internal works are needed?
  6. #116
    Jul 2007
    Canberra
    No noticeable difference in lag.
    In the manual power kicks in about the same 2500rpm-ish
    It's A LOT more responsive, even at lower revs
    The chip increases boost but not positive by how much
    Air filter and exhaust are not essential but if you want a few more kw's always nice to have
    GTI internals are the same on the Pirelli GTI which can be safely and reliably run at 250-ish kw with chip, fmic, exhaust and intake.
  7. #117
    Nov 2007
    Quote Originally Posted by snooze View Post
    In answer to your questions:
    1. There is no more lag than std.
    2. Have a look at the power curve on APR's website, power starts early, @2500rmin you're looking at 400NM
    3. It is much more responsive than before.
    4. Boost is upped to around 1bar. Factory boost is around 0.6bar
    5. There is no need to replace anything with only the chip done. Intercooler, intake and exhaust are all stage 2 items.
    6. The TSI Tiguans all run Mk6 Golf GTI engines already. No internal changes are necessary until you go beyond 300kw. Even the APR Stage 3 kit has no internal engine work and it makes about 300kw.
    Tiguan tuning stages typically would be the following:
    Stage 1 = ECU only = 190kw/400NM
    Stage 1+ = ECU + any 1 or 2 of upgraded FMIC, intake & exhaust
    Stage 2 = ECU + upgraded FMIC, intake & exhaust = 210kw/430NM
    Stage 2+ = Stage 2 + Audi S3 (K04) Turbo upgrade = 240kw/450NM
    Stage 3 = Stage 2 + big turbo upgrade + a few other extras = 280kw/500NM
    And beyond = Engine inernals & even bigger turbo = 350+kw
  8. #118
    Nov 2008
    QLD
    hey Sharkie, I love the Tiguan 190TSI sig. Maybe we should get some new badges made for the chipped tigs
  9. #119
    Coming soon:
    You just need to add delete the "I, II, III" depending on the stages you have.
  10. #120
    Nov 2008
    QLD
    Coming soon:
    Love your work Guy.
