Results 1 to 5 of 5
Thread: Tiguan TSI spark plug gap
Threaded View
  1. #5
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by Ramee View Post
    Could it be the improper install of spark plugs for coil packs caused the trouble in the first instance. Probably when install the second time may have done a better job and problem solved I believe 0.8 is the correct value for GTI version of TSI engine and boost level.
    I am running 0.6 mm gap with no issues but of course with a tune.
    the first install was done the same way, torque wrench to 18ft lbs, BUT the gap was per NGK factory (0.8mm) out of the box.
    the 1-1.1mm gap for CCTA engine (Mk6 GTI) was based on this:
    2013 Golf, GTI & Golf R Quick Reference Specification Book
    https://app.box.com/s/260hhzhywgva8wv9oksu
    my Tiguan is on stock tune.
    MINI Cooper S Clubman - FWD
