Yeah can't wait, are eibach seen as a premium brand over H&R? They seem to cost about $150 extra but forum members are reporting success with both brands.
Read the threads. 100% people have been happy with Eibach. 50% of people pull out the H&R which are slightly lower drop and firmer spring.
I had Eibachs in my old Tig and it's a progressive rate spring. Soaks up the small bumps better than stock and then firms up when pushed. Whereas the H&R are a fixed rate spring and tend to be a bit jittery over bumps. That's according to others reports - I haven't driven a car with H&R's.
Having had the eibachs for about 7-8 months I would recommend 100% but they can be a bit pricey if you just want more low, depends on the kind of driving/roads you are on
Sent from my SM-G928I using Tapatalk
Thanks guys, eibachs it is , for me aesthetics is a nice perk but I want to get it done for handling and to hold the nose steady during heavy acceleration and braking. My other vehicle is a octavia rs so handling is always my biggest gripe when I get in the tiguan.
Tigger, I noticed that there were a few unhappy customers of H&R on the forum after I posted. Anyway can get a set of eibachs for around $400 so really not an expensive upgrade for the benefit.
hey mate what option did you go for?
looking to upgrade my Q3 (same PQ35 platform as Tig)
currently running bilstein b4 with h&r 25/40mm drop and looking for better strut option but can't decide between B6 or Koni Yellow
Bilstein also do a B12 Kit with B6 + Eibach 25/25 drop which could be a good option, it would just mean i'd lose the bigger drop at the rear (unless the strut on the B6's are slightly shorter than the B4s it might work out well with the Eibachs)
The B4+H&R set up still runs ok but I know there's room for improvement for the ride quality even thought cornering and feeling more planted to the road has become better than stock.
