Results 1 to 10 of 11
Thread: Tiguan Suspension
    Oct 2010
    Tiguan Suspension
    Hi guys, i was wondering if anyone could recommend what type of suspension i should get?
    I'm running 19 inch and it now looks a bit high.
    What should i get, coil overs or just springs?
    Any goods site i can get them cheap?
    Regards
    MY10 Tiguan 125TSI /APR Stage 2
    Jun 2009
    Springs are cheap and will drop the height reasonably but also wear out the oem shocks.
    you could get a spring/shock upgrade but then why not get coilovers (which are also more expensive and will usually incur import duty if you bring them in - if over the $1k threshold.)
    H&R make a good set of coilovers which drop about twice the amount of just springs, so do KW.
    May 2011
    QLD
    I've found lowering springs tend to compromise the handling.
    Get a proper coilover set.
    I'm sticking with the ACC
    Oct 2011
    If your Tig doesn't come with ACC can you get if fitted later?
    Jun 2009
    Quote Originally Posted by TobyJ82 View Post
    I doubt it.
    It's one of those funny ones like off-road tech that doesn't seem to be fited post purchase.
    By the way, ACC/DCC doesn't actually set the ride height differently, just the stiffness as far as I am aware.
    Arrawarra
    Quote Originally Posted by DoggieHowser View Post
    I've found lowering springs tend to compromise the handling...
    I've been considering a 'mild' lowering on mine ala Eibach springs. Lowers the car around 30mm, compared to around 60mm with H&R. I wouldn't have thought this would compromise handling, but improve it! Ride comfort would be the compromise, i would have thought?
    Oct 2010
    Thank's guys my mind is set. I will get coil overs, can anyone recommend a brand or location in Melb to purchase.
    I've seen some on ebay, Tracer brand, any good?
    eBay Australia: Buy new & used fashion, electronics & home d
    May 2011
    QLD
    The problem is that the original damper settings are set for a certain spring rate.
    Lowering the springs often changes the spring rate. I've found the cars tend to get very bouncy unless the damper settings can be changed.
    Jul 2010
    Bungendore
    I got the HR springs (second hand from Clip) and am really happy. There seems to be minimal compromise in comfort for improved handling.
    MY10 Tiguan 125TSI | Pearl Black | Manual | Comfort Pack | Kamei Eyelids | MDI | Not Leather | Rubber Floor Mats | Kids | Random Spillage | VWWatercooled Sticker | APR stage I | H & R springs | ECB nudge bar
    Jun 2009
    Quote Originally Posted by Suffolk View Post
    Haven't heard of that brand.
    If you are going suspension i would only go with H&R or KW.
    It is a prety integral part so you don't want to cheap out and get some ebay no name brand.
