...as well as lubricating the sunroof's slides with the correct lubricant.
ive seen this before usualy its the join in the rubber at the top of the drain tube leaking water into the roof. VW will fix this under warrenty. u can see if this is the problem bu removing the grab handle on the offending side and pulling the roof lineing down slightly. u should see water dripping out of the join on the drain tube. hope this helps.
thanks for the help again.. is it possible to just use some kind of super glue so that the drain plug doesnt disconnect ever again? .. i dont want to connect it up only to have it disconnect again.
Is it possible for me to ask vw to pay for dry cleaning of my roof interior where there has been wet patches? There is very slight water stain, not really noticeable unless u really look but noticeable to me.
