Yes, you even as a second owner you have a 3 years warranty and VW should repair it. Just contact any VW dealer.![]()
there is a drain hole for both sides of the sun roof, it runs down the a pillar and exits just under the wiring which goes to the door, if you open the door, you should be able to see a black grommet near the wiring. I have seen these blocked, its also part of VW service to make sure they're clear.
...as well as lubricating the sunroof's slides with the correct lubricant.
ive seen this before usualy its the join in the rubber at the top of the drain tube leaking water into the roof. VW will fix this under warrenty. u can see if this is the problem bu removing the grab handle on the offending side and pulling the roof lineing down slightly. u should see water dripping out of the join on the drain tube. hope this helps.
thanks for the help again.. is it possible to just use some kind of super glue so that the drain plug doesnt disconnect ever again? .. i dont want to connect it up only to have it disconnect again.
Is it possible for me to ask vw to pay for dry cleaning of my roof interior where there has been wet patches? There is very slight water stain, not really noticeable unless u really look but noticeable to me.
