Results 1 to 10 of 18
Thread: Tiguan and the Snow
    May 2009
    Melbourne Victoria
    Question Tiguan and the Snow
    Hi everyone,
    I'm planning to take the Tiguan TDI up to Lake Mountain for one day. Does anyone know whether I need to put anything "special" into my diesel tank? I've had friends who owns the previous X5 model and Prado diesel and they both put some additive in to avoid the diesel from freezing up.
    Contacted my local Volkswagen service centre and they advised that I do not need to do anything. Will only be going for one day.
    Thanks
    Liam
    Jun 2009
    I wouldn't bother adding anything to the fuel.
    Have fun taking the Tig through the snow.
    Be sure to get some pictures and give us a review of how it goes when you get back.
    This is on my list of tasks to put the beast through.
    Might be best to ask Derek (NZ TIGUAN) as he has a diesel and it gets put through cold/snow work.
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    I took my Tig up to the Snowie's last year and had no problem with my Diesel freezing or anything. You'll be fine mate.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Aug 2009
    South Australia
    Hi I always leave space for half a tank of diesel and fill this up at the bottom of the mountain. All the local petrol stations all have alpine diesel with the additive already mixed in. I figure why take a risk when I don't need too
    Dec 2008
    Alexandra, New Zealand
    You'll have no issues at all unless you're going to Antarctica !!! Most snow areas have comparatively warm temperatures, it's only when you're getting into the -20șC range that I'd even be thinking about it !!
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Adelaide hills, SA
    Quote Originally Posted by NZTiguan View Post
    Not exactly. If you park your car overnight at -10deg. and start driving in the morning the cold wind will cause the temperature drop to much more than -20deg on the surface and inside the fuel tank, fuel lines and hoses. That will reduce or stop diesel fuel flow and the engine will stop working.
    But as far as I know we have winter fuel in all states, don't we? That should solve that problem.
    How ever I always use diesel fuel additives, summer or winter doesn't matter. If you going to use additive because you go to snow get the one that is for winter conditions.
    Dec 2008
    Ahh you're fussing too much Transporter tell your Tig to toughen up !! If they (the fuel companies) use something in the diesel in winter it's needed, if they don't it isn't. We often are -10 and more here in Winter and I've never seen a single diesel with an issue and we all just fill-em-up and drive.
    Derek
    Alexandra
    Adelaide hills, SA
    Yeah, I know.
    But, there is a lot of problems with the fuel injection components in late model diesel engines and they're all related to the lack of lubrication from the fuel itself. In most cases after 150,000km. Here is the article that came to me last month http://www.industrysearch.com.au/Fea...esel-fuel-4619
    I'm not telling you go and buy that Bi tron product (I never used/tried it)! The good fuel additive will add a little bit to the running cost which will be compensated by improved fuel economy and longer life of the engine components.
    Apr 2010
    South Africa
    Hi Regulars,
    Back in 1994 with the Winter Olympics in Lillehammer, a work associate and myself was on our way from Hamar to Lillehammer one evening after "work". Work was setting up and testing a stabilized camera on a track next to the speed skating arena in Hamar.
    30 minutes short of our destination, the Discovery l just died and we were towed in. At the time we did not know what the problem was, but the cure was to lock the car in a garage with some air heaters overnight, and we were on the road again the next day. The temperature was probably not much lower than -10 C at the time of traveling.
    So yes, 16 years ago diesel DID freeze in fuel lines, but I would hope that we have advanced somewhat with both the engines and the fuel.
    Dec 2008
    Hopefully in the areas it's needed (such as here in Central Otago) the fuel companies allow for this sort of thing. I guess they must cos as I say I haven't heard anything about problems. That said I guess if you're going from a warmer area into a cold one and not filling up along the way you could end up with an issue, so looking for an additive that "covers your nether region" could be a wise move. I'm just giving Transporter a stir up cos he lives over the ditch
    Derek
    Alexandra
