Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
Thread: Tiguan S3 Intercooler Install Guide
  1. #51
    Quote Originally Posted by Tiggy1 View Post
    Hi Brad,
    Thanks for that - I agree they certainly look like they'll do the job (and at the end of the day it's just a piece of pipe), so how much better could the big name brands be?! I guess I'm just s^&*t-scared of any leaks having heard about what dusting can do to a motor. Same reason why not overly keen on CAI's that used oiled filters - maybe as efficient as paper when properly maintained, but nothing beats good old barrier protection of paper IMO
    First thing is the CAC so am still trying to track one down (preferably S3 plastic end tanks one) - where at are they for $200 odd? Been trawling the 'net without much sucess
    I would have thought there would be some decent second hand ones kicking around from all the guys upgrading their Golf R/S3 intercoolers and having some "unwanted" parts.
    Erskineville, NSW
    Hi Brad,
    I'm not a fan of oiled filters either.
    They *were* as cheap as USD170 but I think people twigged ane put the price up. I did find one for USD195 but can't find it now. Cheapest I can see on a quick search is USD266 new +P&P.
    Put a wanted in this forum, VWgolf.net, OzAudi. You should get a used one for <AUD150. Edition35 / Golf R / S3 / (any with K04 I guess) has the same unit.
    Search for
    1K0 145 803 BP
    1K0 145 803 BE
    1K0 145 803 AK
    This thread might help
  3. #53
    Sep 2011
    Townsville, Nth Qld
    Cheers for that, will continue searching once things blow-over up here (literally).....
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  4. #54
    Sep 2011
    Townsville, Nth Qld
    NEW Intercooler FOR EOS Golf GTI Rabbit Jetta Audi A3 Passat Audi TT | eBay
    Price is right, depending on shipping, but wondering what the difference might be to the "BE/BP"?!
    Says it suits MKV/VI GTI but dunno whether it would still have thicker core (or what other differences might be) ?!
  5. #55
    Anyone heard of a "S" suffix intercooler and what the difference might be?
    It actually looks like it has the same connectors on the end tanks to the stock Tig one. This intercooler looks like the hose fits inside the connector and you then close the clip to lock it in place.
    The intercooler I got I had to cut the aluminium (male) connector off the stock intercooler hoses and then slip the hose over the intercooler connector then put a hose clamp around it.
    So the "S" may be just the difference in the connection type (if all else is the same). It may actually make the job simpler if you don't have to modify your stock hoses and just re-use them as-is.
    Sep 2011
    Townsville, Nth Qld
    It's not just the core thickness that matters. There are some subtle diffrence between a 38mm GTI intercooler & an S3/TT-S IC. Personally, if you have the 38mm GTI IC the next step would be one of the aftermarket providors.
    What I have LOL'd at are those folks that have gone from Golf R/S3 plastic tank to S3 all alloy and claim they can feel an improvement. By all accounts the plastic tank unit performs slightly better.
    I really don't think an IC upgrade will provide any performance gains unless other mods have caused the IC to be a choke point. What it will do is reduce heatsoak & therefore give more consistent power output - esp in hot weather or traffic.
    As above - suits GTI, and same connectors as Tig as you say, but is it thicker core I wonder
    P.S: feel liked I've hijacked Ramee's excellent install thread - feel free to move to new thread moderators if you think would be better
  7. #57
    I suspect it's only 32mm.....VOLKSWAGEN 1K0 145 803 S (1K0145803S) Intercooler, charger
    Sep 2011
    Townsville, Nth Qld
    Yeah, just found similar info.
    Oh well, the search goes on......
  9. #59
    Oct 2010
    Anyone know where I can source some intercooler piping? Installed Wagner intercooler but the piping that came with it was too short and bends were in the wrong place, had to cut oem pipe and install forge ends.
    Problem is, when I turn on Sprint Booster it created too much suction from the intercooler that the ends blew off. Had to limp home and attached stronger clamps.
    Contacted APR but they don't sell piping separately, also rand a few places to custom make aluminum piping but when I said VW, they said bye bye. Any recommendations?
  10. #60
    Oct 2010
