Originally Posted by
brad
Actually, they haven't got "almopst the same x-sectional area". Mine are about 10% bigger when measured at the largest point. The difference is much greater when measured at the smallest x-section. The pancake pipe is worst for this as the x-section is all over the shop. Mine also removed a restriction between the turbo & the pancake pipe.
None of these smaller mods make huge differences in isolation but as a sum-of-the-parts equation it all starts to add up with regards to either power or driveability.
Hi Brad,
See what you mean by the restriction in the pipes (plastic ones that run beside engine) - definitely got that squished look!
Presume the S3 ones are the ones you're talking about that are "rounder"?
If so, would you know part numbers and if they'd be direct replacement (with S3 intercooler and hoses at same time)?
My only other concern is that where it runs past the "front" ( ie. RH side) of engine there could be a clearance problem with the crank pulley/dampener?!
Sent from my PadFone 2 using Tapatalk 2
2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
