Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Tiguan Quirks
    Aug 2009
    North Coast, NSW
    Tiguan Quirks
    Thought i'd create a post with a few of the quirks i have found in the workshop manual and from reading other places around the net.
    Speedo
    The Speedo is incremented every 10km/h from 0-70 km/h then every 20km/h with the same spacing
    Auto Transmission
    If you touch the brake (so the lights come on) the A/T will select progressivly lower gears and engine breake
    Rear Fog Lights
    There is provision for 2 rear foglights, however only the drivers side one is active
    Headlights
    When using Auto Headlights the Park Lights only stay on when the key is left in the ignition
    Headlights come on when you unlock the car if auto headlights are turned on
    Wipers
    A.P.P.
    The windscreen wiper system is equipped with an APP function (alternating park position system).
    With the APS function, the wiper arm is moved up slightly once it has reached the lowest position. This occurs every second time the wiper system is switched off.
    Serivce Position
    Also the wiper "service position" is activated by turning the key On and OFF and then flicking the wiper stalk to put the wipers up so they can be pulled off the windscreen without hitting the bonnet.
    Rear Wiper
    The rear wiper won't work with the tailgate open.
    The rear wiper will wipe if you've turned on (and off) the front windscreen wipers some seconds before and select reverse
    Clock
    To set Time with buttons below rev counter:
    Press the left button h -1- to set the
    hours. Press the button only briefly to
    advance the time one hour.
    – Press the right button min -2- to set the
    minutes. Press the button briefly to
    advance the time one minute.
    To Set Time And Date Using Windscreen Wiper
    – Switch on ignition.
    – Press button -2- for 2 seconds to open
    the main menu.
    – Press button -2- to select the menu
    “Settings” and confirm using button -1-.
    – Press button -2- to call up the menu
    “Time” and confirm using button -1-.
    – Now mark the menu option “Hours” by
    pressing button -1-, set correct hour
    using button -2- and confirm with button
    -1-.
    – For the menu option “Minutes” it is the
    same procedure.
    – The menu “Settings” can be closed via
    the menu option “back”.
    – Now select “MFI” for actual display and
    confirm this using button -1-.
    Electric Windows
    Windows Can be raised or lowered by holding down the lock or unlock buttons on the remote
    The automatic opening and closing features for the electric windows do not function after disconnecting and reconnecting the battery.
    After batteries have been disconnected and reconnected the roll-back function of the electric window regulators is disabled. Severe pinching injuries could result!
    The following work description applies to the front left window regulator. Reactivate the other window automatic functions in the same manner by operating the respective switch in the driver door.
    – Close all doors and windows completely.
    – Hold the front left side window in “closed” position, by pulling
    and holding switch (for longer than 1 second).
    – Pull switch again for 1 second. The side window must now go up or down by itself when switch is briefly pulled or pressed.
    – Switch off ignition
    Imobiliser
    The Tiguan Uses a 4th Gen Imobiliser Some points to remember:
    All (including re-ordered) vehicle keys are pre-coded to a specific vehicle in the factory and can only be adapted to this vehicle.
    It is no longer possible to use other branded keys in Volkswagen vehicles.
    If a door is open when you lock the car, the indicators wont flash until the last door is closed
    Odometer
    Odometer Cannot be modified by VAGCOM (ie. wound back), however it can be wound forward if the replacement odometer has less than 100KM on it
    Compass Module
    Possibly only for models with RNS510? Will need to test and confirm
    To activate the compass module the rear window heating must be learnt as follows:
    Activation must be performed when the engine is not running.
    – Wait 10 seconds.
    – Switch on rear window heating.
    – Wait 10 seconds.
    – Switch off rear window heating.
    Centre Console
    the centre armrest is adjustable for and aft as well as up and down.
    Auto Transmission
    Please try to keep this thread as short as possible. I created a new thread named "Ideas for Tiguan Quirk posts" post your questions and comments there.
    We could make this thread sticky.
    Thanks To:
    NZTiguan
    Sanman
    Transporter
    Jan 2008
    Quote Originally Posted by Torn View Post
    Electric Windows
    Does it do this for all windows after you do one window or do you have to do all the windows???
    The way it works on the Golf and I would have assumed the Tiguan is that after the battery has been disconnected the windows loses the upper and lower position for the auto open/close function and this is set by winding the window down and back up (for each window). After this is done and providing it's turned on in the MFD you can use one touch open and close.
    Aug 2009
    North Coast, NSW
    It was the same on my polo as the golf, i dont have my Tig yet so unable to test, this info was from the workshop manual, the way i read it was that its the funtion that prevents the window from stopping if something is jammed in there, ie. your arm. and also the auto up/down, this is also for the 2010 spec tig
    Mar 2009
    I found out when wiring in the power for the reverse camera - the rear wiper won't work with the tailgate open.
    If one door is open and you lock the car, the indicators won't flash confirmation until the final door is closed
    The auto selects progreesively lower gears and engine brakes if you touch the brake pedal (so that the brake lights come on)
    The speedo increments in 10km per hour segments up to 70km per hour, then magically jumps to 20km/h segments (with the same spacing)
    The front door check strap holds the door at three positions - helps you get out of the car in tight parking spaces - but the rear doors only have two positions (half way and fully open) as per most cars
    Park lights stay (only) on with the ignition off and key in when set to auto headlights
    Headlights come on when car is unlocked with auto headlights on. I think they go off when the key is inserted, or time out.
    There is provision for two rear foglamps, but only the one behind the driver is active
    TDI tiguan in the drive. ParkAssist, comfort, fogs
    Service every 15,000, new fault code every 7,500km
    Nov 2008
    QLD
    auto hold and park brake
    don't remember reading about this in the manual and never had it happen before, but might not have had the same sequence of events...
    tonight on the way home I had the auto hold on which I do most times because of a hill start that I get caught on 7 out of 10 times. Anyway, when I got home and switched off the car in the garage, the park brake activated by itself. As I say, it's never done it before. Can only guess that because autohold was activated and I didn't turn on the handbrake myself before switching off, the car did it for me?
    Sep 2009
    Proved that you can have a DVD running on the RNS510 while driving, you just press the little 'i' button in the top right can corner of the unit then quickly press the 'TONE' button.
    Not sure if the operation of a DVD screen is entirely legal whilst driving, so the obvious cautions about safety etc I used it yesterday so I could listen to a concert recording and just watch the screen when at the lights etc.
    Don't think I'll use it much, but a quirk/trick nonetheless.
    Disclaimer
    VWW cannot be held liable for the consequences of attempting to use any of the mentioned quirks/tricks etc.
    Apr 2009
    Bonnet release is on passenger side footwell.
    Tail lights come on when unlocking, and auto headlights is set on.
    Can not set multi-function display when driving, but can use the screen for other functions.
    Can set the light level for footwell lights.
    Heating ducts for rear passengers, under front seats.
    Curry hooks on b-pillars.
    Nov 2008
    Sydney, Australia
    Smile
    Quote Originally Posted by suparockin View Post
    Disclaimer
    Has anyone else tried this as I tried last night and did not work, I held down the 2 buttons at the same time whist a DVD is playing and driving over 15kph.
    2010 Tiguan 147 Black, Leather, Sunroof, RNS510 with RVC & Park Assist (picked up Dec 16th 2009)
    Jul 2009
    Emerald , QLD
    Speedo error
    Have decides to tabulate the VW speedo error issue
    Started on my Caddy , because GPS in it has a Trip computer - setup the highway portion of my daily commute as test trip, used 2 GPS confirm speed
    -a straight 13km with 1 dogleg over a railway line
    Caddy default pulse setting 1
    pulse......GPS k/h....GPS KM.....Speedo..ODO...S%error......D%error....DIFF%
    22188/1.....95............13.0........100.....13.0....+5 .26%.......0%.........5.26%
    21848/4.....89............13.0........100.....13.9...+12 .35%.....+6.92%....5.43%
    22532/7.....97............13.0........100.....12.7....+3 .09%......-2.30%....5.39%
    will do the Tig, when I can separate it from "she who must be obeyed"
    but I think the jurys in
    1. there is a deliberate 5+% error between the speed shown and what the computer really knows
    2. the pulse adjustment affects both speedo and odo
    3. using the adjustmsnt you could fit 7% over size tyres to the caddy and still be ok
    unfortunately the Tig default is 4 ( the lowsest available)
    Ted Hagstrom
    2009 VW Caddy, Whte, TDi, DSG
    2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
    Apr 2009
    Canberra AUST
    If you leave the indicator on as you turn off the car...
    you get a beeping noise advising you (it took me ages to work this one out)!!!
    BUT it leaves that side park light on (which ever side indicator you left turned on). Probably handy for street parking in city areas.
    2009 147TSI Tiguan, Deep Black Pearl Effect, Black Leather, Sunroof, RNS510, Bluetooth, and MDI.
    Delivered 22 May 2009
