If you mean the transmission sometimes thuds when down changing (usually from 2nd to 1st gear) my 147 does it intermittently. Mine does it when the engine/transmission is hot or cold, more so when I'm quickly decelerating (like at traffic lights).
Hi,
Not sure if anyone else had the same problem. While driving tig when it's cold I noted my car will jump when I hit break. The jump normally happen when the car nearly comes to fully stop. The problem seems to go away after the car warm up. Is this normal or there is some part need to be checked?
Your assistance is appreciated.
Thanks
2009 Tiguan 147 Candy White Black Leather
2012 GTD, DSG, White, RVC, RCD510 Dynaudio, R LED Tails
Yes, I think that came from the transmission. It happens when car is cold even I wasn't deceleating quickly. I read a post while back someone has similar problem but couldn't find the thread again. Just want to find out the cause of it so I can get them to fix at next service.
