Hi Naresh, here's a few from different angles taken with a 10mm lense!
Sorry, but the car needs a wash...
I think you would like the Eibach springs on your Tiggy!
Cheers, Matt
2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
Cheers, Matt
Nice Tig Matt!!!)))
Sounds like a plan! Got family from overseas visiting at the moment so might have to wait a few weeks before we tee up! Good to have a fellow Watercooled member in the west side!
Thanks for the pictures Matt. What size are those wheels and offset, and have you also fitted spacers? They look flush with the arches.
19 x 8.5 ET35. No spacers. They are virtually flush with the arches. This size & offset would be on the limit of upping the spec's without running into troubles, i reckon!
One thing i have noticed since fitting the springs is that when on full steering lock, the tyres on the road seem extra grippy-scrapey... There's probably a term for it, but kind of like if you imagine being in a proper four wheel drive, trying to turn tightly with the diff-lock on, on a hard surface.
Hi can you elaborate on that statement as I wasn't sure if you meant it was a problem or not? From what I read it looks like your tyres rub on full lock? If so what size are your tyres?
I also have 19x8.5 but et28. I have the R Line flared arches but will soon be installing 15mm spacers all round which will then make them completely flush how I like it. I will post up pics when done.
No, not rubbing on anything, all clear there, just the rubber sort of trying to push sideways-ish a bit on the bitumen when on full lock. I moved in with my girlfriend about the same time as getting the springs installed & have to turn quite tightly to park in her drive. It's probably no worse than before, it's just that i notice it more when doing it on a daily basis...
Get the springs!![]()
What sort of fitting cost should I expect for the springs, or length of job in hours?
