Page 40 of 56 FirstFirst ... 30383940414250 ... LastLast
Results 391 to 400 of 557
Thread: Tiguan Picture Thread
  1. #391
    London
    Quote Originally Posted by MGV View Post
    Are you planning on doing this with coilovers? Have found the Eibach springs to be a really good mod for a slight lowering (~30mm) & improved handing characteristics.
    Thanks for that. The Eibach springs are what I keep hearing about and the 30mm drop wouild be perfect as I don't want to go too low - just to improve the look of the new wheels which look a little lost in such big arches.
    Have you any pics of your ride please?
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
  2. #392
    Arrawarra
    Hi Naresh, here's a few from different angles taken with a 10mm lense!
    Sorry, but the car needs a wash...
    I think you would like the Eibach springs on your Tiggy!
    Cheers, Matt
  3. #393
    Nice Tig Matt!!! )))
  4. #394
    Arrawarra
    Quote Originally Posted by HaywireTig View Post
    Thanks, Dan! We gotta catch up one day so you can have a drive, get bitten by the tuned EA888 bug & update!
  5. #395
    Sounds like a plan! Got family from overseas visiting at the moment so might have to wait a few weeks before we tee up! Good to have a fellow Watercooled member in the west side!
  6. #396
    London
    Thanks for the pictures Matt. What size are those wheels and offset, and have you also fitted spacers? They look flush with the arches.
  7. #397
    Arrawarra
    19 x 8.5 ET35. No spacers. They are virtually flush with the arches. This size & offset would be on the limit of upping the spec's without running into troubles, i reckon!
    One thing i have noticed since fitting the springs is that when on full steering lock, the tyres on the road seem extra grippy-scrapey... There's probably a term for it, but kind of like if you imagine being in a proper four wheel drive, trying to turn tightly with the diff-lock on, on a hard surface.
  8. #398
    London
    Hi can you elaborate on that statement as I wasn't sure if you meant it was a problem or not? From what I read it looks like your tyres rub on full lock? If so what size are your tyres?
    I also have 19x8.5 but et28. I have the R Line flared arches but will soon be installing 15mm spacers all round which will then make them completely flush how I like it. I will post up pics when done.
  9. #399
    Arrawarra
    No, not rubbing on anything, all clear there, just the rubber sort of trying to push sideways-ish a bit on the bitumen when on full lock. I moved in with my girlfriend about the same time as getting the springs installed & have to turn quite tightly to park in her drive. It's probably no worse than before, it's just that i notice it more when doing it on a daily basis...
    Get the springs!
  10. #400
    London
    What sort of fitting cost should I expect for the springs, or length of job in hours?
