Page 1 of 31 12311 ... LastLast
Results 1 to 10 of 308
Thread: Tiguan Performance Tuning
    Nov 2007
    This covers both TSI and TDI Tiguans. See respective sections below.
    Tiguan TSI information - All TSI versions (125 & 147 & upcoming 155TSI) share the EA888 engine used in the MK6 Golf GTI. Thus most engine modifications for the GTI works on the Tiguans.
    TSI Tiguan Stage 1 - ECU Upgrade only
    ECU only upgrade typically delivers around 190kw/400NM. In excess of 350NM is available from 1700r/min to 5000r/min. If this is the only thing you ever do to your Tiguan it is worth it. It changes the nature of the Tig, from a nice handling small SUV that has acceptable performance to a real contender.
    Standard manual TSIs will do 0-100 in 8.2s and with Stg 1 in about 6.3s on average. Tiptronics are about a second slower in both cases and DSGs about 0.5s quicker provided you use launch control.
    There are a number of vendors out there doing ECU upgrades. Research them for the best fit for you.
    APR: http://www.goapr.com.au/products/ecu...guan20tsi.html
    GIAC: http://www.giacusa.com/programs.php?mpid=642
    Oettinger: http://www.oettinger.de/en/product-8...40_ps-500.html
    Superchips: http://www.superchips.co.uk/search?m...3&variant=2147
    TSI Tiguan Stage 1+ - ECU Upgrade + CAI (cold air intake)
    This upgrade typically delivers around 195kw/410NM. You can gain anything between 2-5kw with this depending on the brand you go for. Again, there are a number of CAI brands out there.
    AWE Tuning CAI: http://www.awe-tuning.com/products/v...ox-intake.html
    Carbonio: http://www.goapr.com.au/products/int...nio_20tsi.html
    TSI Tiguan Stage 2 - ECU Upgrade + CAI (cold air intake) + Dowpipe / exhaust
    This upgrade typically delivers around 205kw/420NM. The DP on its own delivers a solid 7kw at the wheels. At present there is only APR doing a 3"DP for Tiguans anywhere in the world. An exhaust shop may be able to make you a custom one. The turbo spools up 700r/min sooner than stock and thus delivers you max power and torque sooner as well.
    APR Downpipe: http://www.goapr.com.au/products/apr..._downpipe.html
    TSI Tiguan Stage 2+ - ECU Upgrade + CAI (cold air intake) + Dowpipe / exhaust + FMIC
    This front mount intercooler upgrade normally delivers little extra power. 2-5kw atw at most. However it cools down the intake air temps much more efficiently than the stock FMIC and will keep you making power long after the stock cars are feeling the effects of heatsoak. Heatsoak can rob you by as much as 20kw atw after sitting in traffic for 15mins.
    There are a number of options here, an Audi S3 will deliver 30% extra cooling and is an easy fit. Most of the major tuners have GTI FMIC upgrades available and most will fit with a bit of work (mostly piping) to the Tiguans. Research them for the best fit for you.
    S3 FMIC: http://www.awe-tuning.com/products/v...t/s3-fmic.html
    APR: http://www.goapr.com.au/products/int...r_a3_fmic.html
    TSI Tiguan Stage 3 - ECU Upgrade + CAI (cold air intake) + Dowpipe / exhaust + FMIC + Turbo Upgrade
    Now we are talking serious power.
    K04 Turbo upgrades.
    The K04 is the turbo from the Golf R/Audi S3. It is a standard VW OEM product and larger than the standard K03 turbo. At present APR and AWE Tuning are the only ones doing this upgrade. It is worth 250kw/450NM. This will allow your Tiguan to do 0-100km/h in less than 5s .....
    APR: http://www.goapr.com.au/products/tur...si_k04_au.html
    AWE Tuning: http://www.awe-tuning.com/products/v...turbo-kit.html
    Garret Turbo upgrades.
    This is a much larger turbo than the K03 (stock) and K04 and delivers enourmous power. A number of tuners are doing big turbo upgrades for the EA888 engines. Expect 290kw/500NM from these upgrades.
    APR: http://www.goapr.com.au/products/sta...tsi_trans.html
    VF Engineering: http://www.vf-engineering.com/
    NOTE: Please bear in mind that you may mix and match some of the components for the different stages with great effect.
    Tiguan TDI information - The 2.0TDI used in the Tiguans in Australia all have the 103kw/320NM version. This engine is used widely in other VW models and as such many of their tuning options are available to Tiguan owners.
    TDI Tiguan Stage 1 - ECU Upgrade only
    ECU only upgrade typically delivers around 125kw/370NM. On a manual TDI this will typically improve 0-100km/h times from 10.4s to around 9.6s.
    There are a number of vendors out there doing TDI ECU upgrades. Research them for the best fit for you. Be aware that proper ECU tuning is different from Piggy Back tuning.
    Links to some TDI tuners' products:
    Oettinger: http://www.oettinger.de/en/product-8...70_ps-468.html
    SuperChips: http://www.superchips.co.uk/search?m...2075&year=2010
    TDI Tiguan Stage 1+ - ECU Upgrade + CAI (cold air intake)
    APR TDI CAI: http://www.goapr.com.au/products/int...nio_20tdi.html
    TDI Tiguan Further Stages
    At present I have no knowledge of further tuning on the Tiguans. Certainly some of the Golf TDI further stages may apply. Do your own research if this is what you want to do.
    Adelaide hills, SA
    I will do that, we could also keep it clean, it means no chatting. The second thread for conversation could be made and use links.
    Dec 2008
    Northern Suburbs
    you should add GIAC under TDI stage 1 as they do flashes for them
    Wollongong, NSW
    Fantastic write up Sharkie! Excellent work, Thanks
    2011 Tiguan | 125TSI (5N) | Deep Black | DSG (7-speed) | Launch Control | 4Mo | Fog | Comfort | Bluetooth | MDI (USB + iPod) | Roof Bars | Rear Sensors | Floor Mats | First Aid Kit
    Jul 2010
    Bungendore
    MY10 Tiguan 125TSI | Pearl Black | Manual | Comfort Pack | Kamei Eyelids | MDI | Not Leather | Rubber Floor Mats | Kids | Random Spillage | VWWatercooled Sticker | APR stage I | H & R springs | ECB nudge bar
    Arrawarra
    Thanks for the tip! Have been trying to resist, but that equates to $255 off a stageI upgrade... looking... & wanting... , not needing... , but WANTING... !
    Jul 2010
    Bungendore
    I am in a lot of trouble at the moment. It started with the APR and then moved on to other things...
    Should we start a TOA, or Tiguan Obsessives Anonymous?
    Arrawarra
    Quote Originally Posted by Captain Bungers View Post
    I'm in... We'll just come here for counselling, then?
    Jul 2010
    Yes ... is there a patch you can wear that will help us quit?
    MY11 Tiguan 147TSI (SOLD)
    Jul 2010
    Bungendore
    Quote Originally Posted by aussietig View Post
    Funnily enough, I was down at the chemist today and saw these...
