Lots of hex screws would be required.
I believe there would be some info in the owners manual.
Hi,
Does anyone know how to remove the Tiguan front bumper? Or does anyone have a copy of the workshop manual that may explain how to?
I dont want to just start pulling on things until I know exactly what needs to be removed , etc first.
Thanks
Hey
I took mine off a little while ago to fit the nudge bar...it goes like this:
- Lift bonnet
- Remove two T30 torx screws and one T25 torx screw from above the grille
- Remove 4 T25 torx screws from under the centre of the bumper
- Remove three T25 Torx screws from the front of the wheel arches (one of them is a bit hidden under the protective covering - I had to muck around for ages looking for it).
- Be careful pulling the wheel arch trim outwards from the car - it is held in with push clips that you can reach by wedging your hand around through the rubbery cover)
- Unclip the rear wings of the bumper and reach in and unclip the fog light
- You should be good to go
Just be patient doing it - I managed to get mine off with two toddlers hanging around so it isn't too hard.
Good luck!
MY10 Tiguan 125TSI | Pearl Black | Manual | Comfort Pack | Kamei Eyelids | MDI | Not Leather | Rubber Floor Mats | Kids | Random Spillage | VWWatercooled Sticker | APR stage I | H & R springs | ECB nudge bar
Awesome, thanks mate![]()
Just in case you're trying to locate the "hidden" torx screw, I've had my front end off and eventually found it under the front guard. Here's a picture in case you need to remove your front bumper:
