Results 1 to 9 of 9
Thread: tiguan foglight
    lindfield,nsw
    tiguan foglight
    I've installed front foglight for my tiguan. But it doesn't work. Why?
    Front Foglight option can be enabled in 09 BCM model. Dam, output T52a/25 and T52c/25 for fog lights are blank!!!!!
    How poor my tiguan is.
    BCM should be upgraded to which support fog lights.
    Tiguan 125TSI DSG7 naked version with RVC ,BT9w7 ,OPS ,PLA1.5 ,RNS510 ,150W AC-POWER ,FOG light,LED DRL installed at home
    Multivan comfortline 2.TDI DSG7 with RVC BT9w7 ,OPS,RNS510
    Dec 2008
    Alexandra, New Zealand
    I installed front fogs on mine and simply wired them direct from the battery switched via a relay from the rear fog circuit. My switch gear didn't have the two position foglight switch so this was the simplest and cheapest way.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Arrawarra
    Do i sense a reprimand in red capitals coming on, followed by a "thread moved"??
    Adelaide hills, SA
    Quote Originally Posted by MGV View Post
    As long as the information is useful (thanks NZTiguan) there is no problem to discuss the fog lights. But, I also encourage everybody to stay calm.
    Dec 2008
    Huh ??????????
    Derek
    Alexandra
    Arrawarra
    Sorry, Derek...
    I just think if all related questions about a topic were to be found in one (or 2) threads, it would be infinitely easier to search & find info. I don't think it necessary to start a new thread with each new question...
    lindfield,nsw
    Quote Originally Posted by NZTiguan View Post
    main switch has been already changed to which support foglight. And the signal of foglight on instruments display correct.
    Why I want to install original foglight, foglight can be set to Conner Light when you turn left or right.
    Dec 2008
    Sorry, Derek...
    gotcha, sorry, it's the end of the week (and minus 2º outside) and the brain power's down a bit here !!
    Derek
    Alexandra
    Dec 2008
    Quote Originally Posted by morning View Post
    Ah, well that all makes sense then. Guess you'll have to go the "extra mile" and replace the other bits that don't work for you. Sorry.
    Derek
    Alexandra
