Results 1 to 10 of 13
Thread: Tiguan final drive (transfer case) failure
    Jun 2013
    Probably some of you know I had rear wheel drive not engaging problem of my Tig and I thought it was a haldex failure. But after troubleshooting a lot we (me and a mate) found out that rear drive shaft not deliver power to rear diff & haldex. We actually overlook this problem before thinking about haldex but after car on the hoist second time we notice rear drive prop shaft just jerking trying to rotate but not rotate with a torque. Also it can be rotate by hand when car wheels on the ground not moving. Anyone with any information with this problem please report here..
    Rear drive shaft coming out tomorrow and see if it is just the flange. ( No 10 in the image)
    http://www.jimellisvwparts.com/showA...ey_model=15577
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Feb 2013
    Perth, WA
    Ouch, how long have you had the problem for?
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Feb 2013
    Perth, WA
    Nvmind, I worked that bit out. Will be interested to see how you go with your warranty.
    We have good low mileage used components of 2010 - 2103 Tuguan drivetrain components on the shelf if you need any (Including Bevel drive box off the DQ 500 and complete Haldex rear ends).
    Adelaide hills, SA
    It's good to know that you're ready for the future and good to see the Tiguan still being there 100 years from now.
    Miro, they are good to have when you find the limits of the Golf R drivetrain as well
    Jun 2013
    Thanks PM sent
    Feb 2013
    Perth, WA
    Might be worth taking it to a tech with VW & Haldex experience rather than replace bits.
    Jun 2013
    Update: Transfer case has defiantly gone bad. Took it out from the car after I got a new one from HP. One gear wheel is completely disconnected from its drive shaft(rotate freely) and shaft itself is seized with the bearing. Look like bearing failed and caused all the problems. Oil inside the box was like paste of grounded metal dust and oil mix. very bad
    Looks like part sent by HP got different tooth profile to the original part. Need to sort this out with them now.
    Dec 2008
    Sydney/Canberra
    How many k's were in the borked one?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
