Results 11 to 20 of 26
Thread: Tiguan cruise control missing cluster icon, vag code request.
    Hello YellowLemon, first of all thank you for your helpful information and support.
    Here is my coding:
    Code:
    Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
       Part No SW: 1K0 953 549 CJ    HW: 1K0 953 549 CJ
       Component: J0527           056 0111
       Coding: 0001132
       Shop #: WSC 02244 264 181995
       VCID: 7CFC439A3FF0469
       Part No: XXXXXXXXXXX
       Component: E0221           002 0030
    No fault code found.
    Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
       Part No SW: 5N0 920 871 C    HW: 5N0 920 871 C
       Component: KOMBI         H05 0305
       Serial number: 00000000000000
       Coding: 110F00
       Shop #: WSC 01324 020 00200
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
       ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
       VCID: 3162A2AE60327B1
    Now, I have some questions and considerations...
    • Comparing both scans it seems that I have an older version of SWCM and a higher version, sw and hw, of CLUSTER, so I think the culprit is the SWCM.
    • AFAIK you should have both indicators, icon on the MFD and green light on the speedo, but this can be a wrong information and should be confirmed by someone else that has a stock CC fully working.
    • Where have you found what the coding of cluster mean? On Ross-tech site they discourage change the coding and they don't give other information, so I'd exclude it as the problem, but just out of curiosity.
    • I've checked the adaption option of channel 17-Instruments and at the Cruise control display channel it says "Channel not available", could you check what it says yours?
    Cheers.
    Mar 2011
    Gold Coast QLD
    It seems from autoscans we have same SWCM SW 0111 and you have slightly newer SWCM part number 1K0 953 549 CJ, I have CH (I got from ebay). (Link http://www.vwwatercooled.com.au/foru...odule_Versions )
    Also cluster is same part number (C is for petrol and B is for diesel I think) and you have newer SW version. When I go to Adaptation -> Cruise control display I also get "Channel not available" just like you.
    So difference must be just coding??? Or maybe it is to do with ECU instead??? I suggest you try coding your cluster to region "AUSTRALIA" for an experiement. This should be OK, you can change it back. This is my cluster coding:
    Tiguan cruise control missing cluster icon, vag code request.-new-cl1-png
    Tiguan cruise control missing cluster icon, vag code request.-new-cl2-png
    Tiguan cruise control missing cluster icon, vag code request.-new-cl3-png
    Tiguan cruise control missing cluster icon, vag code request.-new-cl4-png
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
    Ok, I'll try coding the instruments to Australia and see what happens...
    I have another question about the scans difference: why I don't have any subsystem in my steering wheel channel that you instead have? What is a subsystem?
    How can we check if the difference is between ECU? Have you changed yours? Because otherwise mine should be newer than yours, but again I read of other people who has a my2009 and the cc display on MFD.
    Thanks.
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by Toki View Post
    The subsystem in this case is the little slave controller box inside the MFSW under the airbag which connects the buttons and paddles in the steering wheel. In mk6 it runs on LIN2.0 bus and connects to SWCM through slipring/clockspring. If you have MFSW buttons (even mk5 style) then you should also see subsystem in VCDS I believe????
    How can we check if the difference is between ECU? [..] mine should be newer than yours, but again I read of other people who has a my2009 and the cc display on MFD.
    Yes sorry I don't think it's ECU. Everything else electric on my car is original old Mk5 style. Just SWCM and MFSW and CLUSTER (and RNS510 and 9W7 BLUETOOTH retrofit etc...)
    Mar 2011
    Gold Coast QLD
    My full scan:
    Code:
    VCDS Version: 14.6.0.0
    Data version: 20140601
    Chassis Type: 5N (1K0)
    VIN: WVGZZZ5NZ8W******   Mileage: 0km-0miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 AA    HW: 03L 906 022 G
       Component: R4 2,0L EDC G000AG  1998
       Revision: --H01---    Serial number: VWX7Z0H33NE115
       Coding: 0000175
       Shop #: WSC 83968 930 682118
       VCID: 64C716FDA7038D1A8F-8031
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans        Labels: 09G-927-750.lbl
       Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
       Component: AQ 250 6F           1124
       Revision: 00H76000    Serial number:
       Coding: 0000328
       Shop #: WSC 01324 785 00200
       VCID: 78FF528D0B8B79FA33-802D
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 K    HW: 5N0 614 517 K
       Component: J104    C2 450 V1   0006
       Revision: --H11---    Serial number: 00000001024357
       Coding: 0006434
       VCID: 36639CB5411F4F8AE1-8063
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 76E35CB5019F0F8A21-8023
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Component: Bordnetz-SG     H54 2202
       Revision: 00H54000    Serial number: 01000008240707
       Coding: A4880B8300041C004719000014000000000958435C000114390000000000
       VCID: 6FED69D17EC53E42E2-803A
       Subsystem 1 - Part No: 5N2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 250308  012 0203
       Coding: 00038805
       Shop #: WSC 01324
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__202 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DP6KDB3H
       Coding: 0012338
       VCID: 3B758D817A3D92E21E-806E
       Subsystem 1 - Serial number: 6333FTS634260798
       Subsystem 2 - Serial number: 6343FTS651540788
       Subsystem 3 - Serial number: 6353ETS6CDHVSVNH
       Subsystem 4 - Serial number: 6363ETS61C6TSVNP
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Coding: 0001632
       VCID: 7AFB488535876BEA45-802F
       Subsystem 1 - Part No: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H30 0036
       Coding: 00000131
       Shop #: WSC 00000
       Part No SW: 5N0 920 871 B    HW: 5N0 920 871 B
       Component: KOMBI         H05 0206
       Coding: 710E00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 306FAAAD6B7B61BABB-8065
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 070408F1003730
       Coding: FD827F064006026003
       VCID: 306FAAADA37B61BABB-8065
    Address 22: AWD        Labels: None
       Part No SW: 0AY 907 554 B    HW: 0AY 907 554 B
       Component: Haldex 4Motion      0039
       Coding: 0000005
       VCID: 4A9BD84525E73B6A95-801F
    Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
       Component: IMMO          H05 0206
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 680 F    HW: 1T0 035 680 H
       Component: RNS-MID       H61 3970
       Revision: AB001001    Serial number: VWZ6Z7L9365009
       Coding: 00000440010000A00009
       Shop #: WSC 00229 211 17803
       VCID: 3169AFA9687168B2B4-8064
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 5N0 959 701     HW: 5N0 959 701
       Component: Tuer-SG         006 1206
       Coding: 0000758
       VCID: 72EB60A56DF713AA0D-8027
    Address 44: Steering Assist        Labels: None
       Part No: 5N2 909 144 A
       Component: EPS_ZFLS Kl.163 H08 1902
       VCID: 3169AFA9A87168B2B4-8064
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
       Component:    KSG PQ35 G2  020 0205
       Revision: 00020000    Serial number: 00000000000000
       Coding: 9A800A0052834C3F3F04840560089F0B80F940
       VCID: 03053561424D2A2216-8056
       Subsystem 1 - Component:   Sounder n.mounted
       Subsystem 2 - Component:       NGS n.mounted
       Subsystem 3 - Component:      IRUE n.mounted
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 5N0 959 702     HW: 5N0 959 702
       Coding: 0000758
       VCID: 73E565A112ED1AA206-8026
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
       Component: J540 EPB3  VW-09384 0005
       Revision:   H08       Serial number: 00000000054219
       Coding: 0000057
       VCID: 2E53B4D5B94F774AA9-807B
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
       Part No SW: 5N0 959 703     HW: 5N0 959 703
       Component: Tuer-SG         006 1301
       Coding: 0000208
       Shop #: WSC 01324 785 1012551
       VCID: 74E766BD17E31D9A1F-8021
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
       Part No SW: 5N0 959 704     HW: 5N0 959 704
       Coding: 0000208
       VCID: 75E15BB91C99049228-8020
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007662931648
       Coding: 0210000000010110
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A7B8885BD07ABEA05-806F
    Mackay QLD
    Judging by your posting times Yellowlemon are you a bit of a night owl? Excellent work BTW
    Quick question have you been able to enable an option in the lights and vision sub menu called "ambient lighting' when you retrofitted the white MFD instrument panel and footwell lights?
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by Bambazonke View Post
    Unfortunately I completely lost the "lights and vision" and also the "comfort" menus in the white MFD, because the mk5 CECM and CCM can't talk to it! They can only talk to the red screens. I have to do all setting in VCDS now But that is OK I never change those menus anyway - it's set and forget really.
    If by "Ambient lighting" you mean running the footwell lights while driving - then no I can't do this. Even though my CECM with part number 3C0 937 049 AH has a checkbox in VCDS called "Active footwell lighting while driving" (or similar), it doesn't work - as soon as engine is started footwell lighting is off.
    On the steimei website it says to run 'ambient' footwell light while driving you need at least CECM / BCM with part number starting 3C8 (older Tiguan) or 5K0 (facelift Tiguan based on Golf mk6 because 5K is Golf 6 chassis number )
    3C8: stemei.de .VCDS Codierungen .Codierungsservice .Webdesign - Stefan Meier - Fussraumbeleuchtung - VCDS Codierungen, Webdesign
    5K0: stemei.de .VCDS Codierungen .Codierungsservice .Webdesign - Stefan Meier - Fussraumbeleuchtung - VCDS Codierungen, Webdesign
    Quote Originally Posted by YellowLemon View Post
    Sorry for the late followup, I haven't got the chance to do AUSTRALIA coding test nor check the full scan you kindly posted, thanks for that!
    The subsystem thing is a bit weird: I've a MFSW mk5 style and the buttons works well
    I've some old scans that I can check, I would like to exclude some connection error during the installation of the cruise control being made 2 weeks ago by a VW mechanic (I have to say a great one, so I tend to exclude right now this kind of problem), anyway the fact that I don't have a subsytem sound strange...
    Tomorrow I'd have time to do some more tests and post my full VCDS scan (I have an old notebook dedicated to VCDS ).
    Cheers.
    Ok, I've finally got the opportunity to try the Australia coding and unfortunately no luck it doesn't show the CC icon on the MFD.
    Later I'll post the full scan(I'm posting this from the phone), there are some difference, but I don't know if the problem is there...
    Cheers.
    Ok, finally this is my full scan.
    There are some difference that I don't know what they are:
    1. I don't have channel 46 cent. conv., what is?
    2. I have channel 1c and you don't, why?
    3. I don't have a lot of subsystem that instead you have, in particular channel 15 airbag () and 16 steering wheel...
    An aside note: I don't know why I have such phone error, I didn't have them before and the phone works great, I've tried to delete them, but they come back, I'll try to change the coding...
    Code:
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 1K0
    10-Park/Steer Assist -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
       Part No SW: 03L 906 022 RP    HW: 03L 906 022 RP
       Component: R4 2,0L EDC G000AG  6188
       Revision: 13H03---    Serial number:
       Coding: 0000175
       Shop #: WSC 38247 000 1048576
       VCID: 840CBB7AC700BE9
       Component: AQ 250 6F           1705
       Revision: 00H90000    Serial number:
       Coding: 0000328
       VCID: 78F45F8A0BC86A9
    Address 03: ABS Brakes        Labels: 5N0-614-109.clb
       Part No SW: 5N0 614 109 M    HW: 5N0 614 109 M
       Component: J104    C4 450 V2EF 0003
       Revision: --H28---    Serial number: 00000002569772
       Coding: 0011567
       VCID: 356A96BE5C5A571
    Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Component: Climatronic   H15 0709
       Revision: 00003001
       Coding: 0000000002
       ASAM Dataset: EV_Climatronic A01006
       ROD: EV_Climatronic_VW36.rod
       VCID: 7DFA4E9EECEA4F1
    Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
       Part No SW: 5K0 937 086 C    HW: 5K0 937 086 C
       Component: BCM PQ35 M    011 0028
       Revision: BC011001
       Coding: 40180A3B98251AC0400800801500812443613088524D81605C8000000000
       VCID: 346CABBA97204E9
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 11021  012 0203
       Coding: 009795
    Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
       Part No SW: 1T0 919 475 H    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0110
       Revision: --------    Serial number: 88591003230538
       Coding: 100103
       VCID: 4084F76AD398E29
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__200 VW10 HI   1916
       Revision: 20013000    Serial number: 003E2P2DFJLS
       Coding: 0012336
       VCID: 448CFB7A0780FE9
       Coding: 0001132
       Coding: 110F00
    Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
       Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
       Component: J533  Gateway   H20 0592
       Revision:   H20       Serial number: 040210F2002042
       Coding: FDA27F06001602006002
       VCID: 6BDE70C64A9ED11
    Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223T7E4704
       Coding: 0000002
       VCID: FEF8C992A9ECD49
       Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
       Component: Haldex 4Motion      0041
       Coding: 0000005
       VCID: 4B9ED0462ADE311
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H05 0305
       Coding: 000000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
       ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
       VCID: EAD0F5C20D64489
       Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
       Component: Tuer-SG         009 2101
       Coding: 0000180
       VCID: 366891B2415C5C9
    Address 44: Steering Assist        Labels: 5N1-909-144.clb
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.163 0703
       Revision: 1AH03828    Serial number: 00093380073802
       Coding: 0000258
       VCID: 3A7085827544B89
       Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
       Coding: 0000180
       VCID: 37769CB64656A51
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 B    HW: 3AA 907 801 B
       Component: J540 EPB4  VW-49878 0004
       Revision:   H17       Serial number: 00000000001989
       Coding: 0023057
       VCID: 3064A7AAA338729
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
       Component: RCD510        H04 5018
       Revision: -----21S    Serial number: VWZ4Z3N1116805
       Coding: 0500040004000C
       Shop #: WSC 01357 011 00200
       VCID: 2B5EB0C64A1E111
       Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
       Component: Tuer-SG         007 2102
       Coding: 0000144
       Shop #: WSC 01324 020 1012552
       VCID: 38749F8A4B48AA9
       Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
       Coding: 0000144
       VCID: 39729A8E7042B31
       Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
       Revision: 1B001001    Serial number: 00AAAA63112800
       Coding: 0A00000000000001
       ROD: EV_UHVNA_VW36.rod
       VCID: 3B7E8086B27E811
    End   ---------------------------------------------------------------------
