Results 1 to 10 of 10
Thread: Tiguan connecting accersories direct to battery
    Oct 2012
    melbourne
    Hello All
    I am intending to fit a brake controller for towing to my 2010 Tig. The manufacturer of the controller states that the + / - should be connected direct to the battery terminals this I understand. VW have told me that I cannot do this ?? If I do then the car will know that extra powe is being drawn from the battery and will cause a fault.
    Can anyone confirm if they have fitted a brake controller this way without any problems.
    Or any other accessory for that matter I am sure that there are a lot of guys who would connect power to large amplifiers etc. that would connect this way.
    Kevin
    Dec 2008
    Alexandra, New Zealand
    I wired my retrofitted front fog lights direct to the battery, switched with a relay off the rear foglight switch and never had an issue. That's to a 2008. I find it a bit hard to believe that the Tig would know the "total" draw from the battery at any one time as there are a number of circuits that are not load monitored as far as I know. That said I'm no auto-electrician !!!
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Oct 2010
    Hobart
    I have a 2 way radio wired direct to battery by radio tech and have had no problems
    Steve
    2010 Tiguan TDI, auto, tow bar, comfort, offroad, fogs, Mountain Grey
    Adelaide hills, SA
    Quote Originally Posted by ausiekev View Post
    Hello All
    Kevin
    Well, whoever told you that, he was wrong. It would be wiser to say that all the wiring needs to be done according to manufacturer's requirements. Especially the wirings for the mobile phones and the 2 way radios.
    The direct battery connections can be done as long as you connect the fuses there as they should be.
    Pacific Paradise QLD
    Let me say here that you should NEVER use a fuse in a brake controller circuit.
    Why??? If it blows the controller wont work.
    It should have an AUTO RESETTING CIRCUIT BREAKER in the + line so that if it trips it will reset and still give you brakes, Maybe intermittently but brakes never the less A common error which could conceivably kill you.
    All other accessories should have individual fuses as close to the battery as possible.
    A bus bar box is a good idea with individually fused circuits.
    Im not a sparky but have put all the extra wiring in a Landcruiser.
    Extra battery and isolator, Anderson plugs and 6 gauge wiring for van batteries, EGT, Auto temp gauge, Low water alarm, Digital engine temp gauge, RVC with dual power supply RVC on caravan.
    Dont know about the Tig but was told not to connect to battery in the Passat Bluemotion. Also told dont stuff battery as they are about $800
    Adelaide hills, SA
    Of course, that's obvious. All the circuits should be connected as per instructions. Thanks for making it clear. Also all work should always be done by qualified personal.
    Sent from my GT-N8000 using Tapatalk 2
    From looking at some vehicles on my travels its not really obvious as lots had fuses when the instructions say an auto reset breaker.
    Always some one either doesn't read instructions or "knows better"
    Isn't illegal to do low voltage car work yourself but you do need to know what you are doing.
    Decided to do my own after a "professional" did a stuff up. LOL
    Adelaide hills, SA
    Of course not. It only when something goes wrong, you're responsible for it.
    That's obvious isn't it?
    Yep very true but after more than 50,000km of vanning it never even blew a fuse so I guess I may have done it right.
    Adelaide hills, SA
    It was meant in general. I saw a lot over the years and not just the electrical.
