Finally got a "premium" cluster with the colour MFA and am happy to report it's (almost) plug and play swap! For a facelift Tiguan there would be only a few steps:
1) Go to someone local with an immo tool like AVDI and read the cluster IMMO data and save as a .HEX file. This file is very small <1kB and contains all the immo data from the car, including the "component security" code, which are the bytes that have been burned into the key transponder. Cost ~ AU $100, takes all of 30 seconds at the auto electrician. Looks like this:
2) Buy a new or used cluster online preferably from a tacho specialist (rather than a wrecker) - numerous overseas eBay sellers are gurus in instrument clusters and have the tools and knowledge to adapt the new cluster to your car using just the HEX file from above. Cost EUR 300-700+ including coding and shipping, depending on the cluster condition, how many scratches...
3) Swap your cluster - takes less than 5 minutes. Unclip 1 trim piece, undo 2 torx screws with a magnetic driver, the cluster slides right out - then unlatch the plug at the back. Fitting is reverse of removal. Then use VCDS to code the odometer value.
4) "You now have the premium colour cluster. Prepare to get laid." (That's a quote from another forum, love it) Some pictures for your amusement below.
- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
Thanks for the wealth of information YellowLemon.
I've been wanting to change my white MFD to a full colour for a while, but have not been able to obtain a replacement. I'm considering buying one new from the dealers, but looking at ETKA, even with your helpful info that the second last digit is an 8 if a colour MFD, I still have a few options to choose from.
ETKA shows the following 300KM/h parts which I assume would be the blue needle variety
- 5K6 920 882 BX
- 5K6 920 882 EX
- 5K6 920 883 BX
- 5K6 920 883 CX
For the GTi 280km clocks it gives
- 5K6 920 882X
- 5K6 920 883X
Any idea what the difference is? What is the part number of the red needle version you bought?
'10 Reflex Silver mk6 GTi, Xenon lights, Sunroof
Mods: R LED rears | Door lights | Underseat Drawers | Retro MDI kit | Retro passive TPMS | Retro PDC | Retro RVC | Retro Satnav | Retro 9W3 Bluetooth | ED35 bodykit | 18" "Durban" OEM wheels | S3 jack pads | S3 intercooler
