Results 1 to 10 of 10
Thread: Tiguan Carbon Fibre Hood
    Jun 2013
    Saw this in website - alibaba.com, Anyone interested or any ideas!!
    Tiguan Carbon Fibre Hood-811382667_787-jpg
    Tiguan Carbon Fibre Hood-811382678_579-jpg
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Jun 2009
    Well the Tiguan bonnet is extremely heavy so it would be a good starting point.
    Not sure why they decided to put the hood there other than maybe to push air back to cool down the turbo?
    However alibaba usually require you to buy in bulk and shipping on this is going to be a killer.
    Also carbon fibre panels are a bit sketchy with ADR compliance.
    You would likely do better ditching the spare tyre and all the impact reduction bars (giant metal beam behind the bumpers etc)
    I'm not sure it's going to have a massive effect on performance with weight saving. Looks wise I prefer to be a it more discrete so if I was to change the bonnet it would be without a scoop.
    May 2011
    QLD
    I'm usually wary of buying aftermarket parts from China. Most Carbon parts are really just fibreglass with a few layers of CF for looks.
    When I was heavily modifying my old Evos, I'd often get parts from Japan. They cost more but there was real R&D employed in the design and the build quality was top notch. I used to run a full Test and Service bodykit and CF bonnet with a CWest wing. The downforce through corners in Sepang and high speed stability was very noticeable.
    Ps with lightweight CF bonnets, I found I needed bonnet pins to hold down the bonnet when traveling at high speeds.
    The bonnet would need to be ADR compliant (and generally tested) to qualify - which would make 99.99% illegal. This will generally relate to pedestrian safety. Could cause an insurance risk as well, even if you're not worried about a possible defect.
    Agreed on the bonnet scoop as well - unless you want a WRX/Forester Turbo look.
    Bit of a link here to the SA regs, that's the easy bit.. it's the ADRs that are a fail:
    sa.gov.au - Aftermarket components
    Jun 2013
    Quote Originally Posted by team_v View Post
    This product is listed there as the minimum quantity of 1. So I think buying one of these possible. I sent a request to manufacture asking for price and shipping. Considering it is from china shipping can not be that much expensive I suppose. But will see how they respond to my email.
    I like the hood scoop design Ok may be I like WRX look haha! If I fit this in to the car it will be more like a big mini cooper S.
    Jun 2013
    According to VicRoads CF hoods are not approved.. So this looks like a no go
    Jun 2013
    Found some pictures with CF hood installed ..
    Tiguan Carbon Fibre Hood-s-jpg
    Not the best look for a Tig though , seller quoted me 433USD for the hood.
    Jun 2013
    Jun 2014
    I'd like a front lip and a carbon bonnet,but not either of those options.
    Justin...
    Justin - Enthusiast's Warehouse. Need parts? Pm me.
    Cars in the driveway: 2021 Passat B8 RLine 206TSI Wagon, Mk8 Golf 110TSI Wagon, Toyota AE86.
