Results 1 to 8 of 8
Thread: Tiguan and caravan
    Oct 2012
    melbourne
    Tiguan and caravan
    Hello
    Anyone charging a caravan battery via an anderson plug fitted and wired to Tiguan battery ???
    Need to know if I can connect cables to Tiguan battery without causing a fault in the Tigs electronics
    Kevin
    Adelaide hills, SA
    It all depends how will you connect it. The best way is to get 12VDC to 12VDC charger like Red Arc BCDC1220 or BCDC1240. That's the safest way.
    Oct 2012
    melbourne
    Thats what I intend to do but VW have told me that if I connect anything to the battery even a brake controller then the car will pick that up and throw up a fault. I cannot understand how all the other guys on here are able to connect aux amps etc. etc. direct to the battery without causing a problem
    Kevin
    Adelaide hills, SA
    What built date is your Tiguan?
    The latest one with the stop-start technology could be more sensitive when you put extra load on the battery, but it still should allow you to connect that BCDC1220 to the system.
    Oct 2012
    melbourne
    2010 model
    Adelaide hills, SA
    You will have no problems installing that DC charger to your Tiguan. Our Tig is 2010 and it didn't through the code when I connected BCDC1220.
    Oct 2012
    melbourne
    Thanks for that just when i spoke to the dealer and asked about a brake controller they told me that I cannot connect anything direct to the battery. They also told me the cost would be If I supplied the unit between 750 and 950 dollars just to install it
    Kevin
    Adelaide hills, SA
    That's ideal DIY project and if you know the basics about the car el. circuits and follow the instructions which always come with the dual battery systems, you should be able to DIY. Or you could find the independent vw shop who would do it for you. If you go with the BCDC1220 or 40 it's even easier. Check the ebay you can get kit to suit.
    I don't recommend the classic dual battery controllers, because the dcdc battery chargers just do a better job and are easier to install.
    Sent from my GT-N7000 using Tapatalk 2
