Results 1 to 10 of 20
Thread: Tiguan boot hatch release
    Jun 2009
    Tiguan boot hatch release - solved
    Hi guys,
    I am trying to find a way to open the boot whilst having the car running/key in.
    In the last few weeks i have had to turn the car off and pull the key before the boot hatch would unlock so that a passenger could put stuff in the boot.
    Is there any vagcom coding or any process which i am not doing properly to get the boot to open while the car is still on as it is rather frustrating having to turn the car off for 10 seconds so someone can grab their esky etc from the boot.
    Solution = press door unlock button on driver's door
    Adelaide hills, SA
    You should be able to change it via MFD. I can open the doors inc. hatch by pressing unlock button on the driver's door. I have it set to auto lock when you reach 15 or 20km/h and when unlocking, to unlock only the drivers door.
    Jun 2009
    Transporter, i deactivated the auto lock feature as soon as i got the car so it shouldn't be that.
    I tried unlocking the boot via the keyfob while i was in teh car (key still in teh ignition) and it still wouldn't work.
    Will have a look on Thursday night and see if i can read the manual about it.
    Adelaide hills, SA
    So, did you set it to unlock all doors when you open the car using the key?
    Jun 2009
    Yes, it unlocks all doors.
    Might have to have a play around with the MFD/manual to see if there is anything i missed.
    Aug 2006
    Far North Qld
    Clay, as discussed I tried this arvo
    at first start up went to back door, no problem in opening
    after having driven for few kms, above recommended speeds (- no proplem opening while engine running
    any other permutations, am happy to try...[-:
    rear door opening works every time when hands properly inserted under rear hatch door catch...
    Dec 2008
    Sydney/Canberra
    ^ Correct.
    Hit the unlock button on the driver's door, and then the boot can be opened externally via the release on the bootlid.
    As to why you've disabled the Anti-Carjacking devivce, I'm not sure...
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Nov 2009
    Northern NSW
    rattle from rear door
    team V sorry to hear you are having hassles, hopefully you will find a logical explanation, per Transporter I just unlock mine with unlock button in car, but looks like you have explored that
    Slightly off topic I know, but has anyone had any trouble with their rear door being slightly loose? You can move it just slightly when its locked on ours and we have an occassional rattle from the back over bumps that I now suspect is the rear door itself. So interested if anyone else experiencing similar problems or has any clues on adjusting so no longer loose.
    Tiguan TSI Catalina blue, Manual
    Dec 2008
    Sydney/Canberra
    I've found a few strikers loose in my travels. Check that. Sometimes it shows that the bootlid is ajar on the MFD.
    '01 Beetle 2.0
    Jun 2009
    I didn't try the door unlock button on the driver door, i will give it a whirl tonight.
    I tried using the keyfob boot button but it won't work while the car is on for some reason.
    Will try a few things when i get home tonight and let you know if i find a solution.
    As to why i disabled the auto-lock, no one seemed to like the idea of being locked in, even though i told them there is a failsafe that will auto-unlock in the event of an accident.
    I have never even seen or heard of a carjacking in Aus though so i don't think it is really necessary.
    Boot hatch isn't loose though Jimbo, in fact the only rattle i did have was from the engine mount.
