Okay found the solution.
Pressing the unlock button on the driver's door will allow the boot to open while the ignition is on.
Might have to see if i had the MFD settings changed as it should all unlock upon keypres but at least i have a solution.
Yep, that's what I told you at the beginning. It unlocks all doors.It, will not unlock them when you lock the car from the outside with the remote or key and leave the window down (it is deadlocked then). It means when the burglar smash the window, he still can't open the door.
Derek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
It's quite common in Sydney these days. Stealing a modern car is very tricky now, so the only way to do, it seems, is after the owner has unlucked it for them.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Same here if it's too hot a day or if it's for an extended time but if you're simply going into the shop and want the car locked so your car AND your pet don't get stolen then it works well (I haven't used it, my Maine Coon cat's bigger than a lot of yappy little lap dogs but he doesn't like car rides !!).
Derek
Alexandra
