Results 1 to 7 of 7
Thread: Tiguan APR STG1 - Very happy
    Feb 2013
    Perth, WA
    So I got my APR Stage 1 today.
    I'm super impressed with the performance increase. The Tig sure does lift quite a bit when you get on it. Hopefully the H&R sport springs will help a little with that but I'm thinking I might need a complete solution.
    I promised myself that I would stop at that but I've decided to order the Carbonio intake as well.
    The stage 1 makes power delivery much smoother, it does however make the bad shifting habits of the DQ500 DSG more obvious. I think the only thing that would improve that is a DSG tune/flash as well.
    Who else has a STG1 or STG1+ Tig and have you done anything about the Trans or Suspension?
    I do have to say that the APR Dealer in WA (Quattro) was fantastic. Great service and very friendly. They are certainly a busy bunch so do you have to be a little patient but they always come through with the goods.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Hahaha once you start you can't stop I'm sorry.
    Yes I've had the DSG reflashed with the HP DSG software and it does make things a lot better for "normal" driving.
    Also installed anti-lift kit which helped quite a bit with the nose diving/lifting during acceleration/braking. Also springs helped with this too though I put the ALK on first and it made a big change. Plus front/rear sway bars (recommend rear / front is optional) to reduce body roll when cornering.
    Feb 2013
    Perth, WA
    Just did a run with the Autopolar. Timed the 0-100 with the Chronometer function and got 5.398 (17.5c) outside. I'm pretty happy with that
    I'm sure if I use proper timing equip I'll probably get more of a 5.6-5.8 but I'm still ecstatic.
    Quote Originally Posted by Wynnston View Post
    Gotta be happy with that
    I'm assuming that time is with LC.
    Feb 2013
    Perth, WA
    Ah yep
    Jun 2013
    Ah yep
    Congrats mate !! Yep once you start it is hard to stop Considering Tig is built for towing up to 2 Tons of weight it is very good platform for performance mods. Transmission / suspension/ chassis should be able to handle extra stress form power/torque increase. Even upcoming RS Q3 comes with same DQ500 transmission in Tigs with 420 Nm torque and 311 hp.
    One piece of advice, try to go slow step by step doing performance mods giving enough time for car and you to settle with new found power; in that way you can enjoy every step of power increase Carbonio intake is good complement mod for APR stage 1 and if my memory serves me correct APR mentioned it should give more power than stage 2 + downpipe (without intake).
    After getting APR tune I too noticed DSG rough shifts and after some time (few weeks later) DSG seams to be settled with the new power increase.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Feb 2013
    Perth, WA
    Thanks Ramee,
    I've spend the weekend in the city and the stop and go traffic has certainly made its clunkyness show. Hopefully it will relearn soon.
    It's almost like the clutches aren't biting hard and quick enough or the shift points just need to remap so that it doesn't try shifting so early. I'm guessing it's torque sensitive and the increased torque is making it think to shift earlier.
    I was thinking of doing a DSG Reset (Basic Settings in VCDS) but I can't find a procedure for the DQ500. Does anyone have one hidden away? Ross-Tech don't have one yet because there are no DQ500's in North America that I know of.
