Results 1 to 3 of 3
Thread: Tiguan 2.0 TDI Intake Manifold Replacement still leads to a P2015 manifold error
    Dec 2022
    sweden
    Hello.
    The car I have bought recently with 230 000 km under the belt seems to have a lot of issues with the infamous P2015 error code. I also had an issue with the EGR Valve which i replaced and didn't get any more codes regarding that.
    I ordered a new intake manifold and replaced the old one and I hoped that the issue would be gone, but however, after a shorter ride with the car today, I still get the p2015 error code, together with a check engine light in the panel.
    Running out of ideas and money for this car. Any ideas what the issue might be?
    Attached Thumbnails Attached Thumbnails Tiguan 2.0 TDI Intake Manifold Replacement still leads to a P2015 manifold error-6534-drm21804_large_1-jpg
    Dec 2022
    sweden
    From what I can read, I need to do adapt the new flap motor / intake manifold with the car. Does anyone know if this is possible to do with obdeleven or do I have to buy proper VCDS tool? How would you do the adapting with VCDS?
    VCDS can lead you through the process, assuming there is one. Usually you press a button and it does it itself. Bound to be a how to on tdiclub or youtube
