Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: TIGR's 2015 Tiguan 155TSI R-Line (Reflex Silver) - Build Thread
  1. #21
    A few have looked into it but it is prohibitively expensive. Just to get all the plastic parts will set you back $2.5-$3k then painting plus fitting is about $5k all up. Much cheaper to buy from the factory as an option.
    Feb 2015
    Sydney, Australia
    Quote Originally Posted by TIGR View Post
    Upcoming upgrades
    Supaloy Control Arms - APR - High Performance Development for Audi, VW and Porsche Vehicles.
    Sway Bars - APR - High Performance Development for Audi, VW and Porsche Vehicles.
    I'm also looking to fit the Turbo Muffler Delete... has anyone got a Tig with this fitted?
    Hey TIGR,
    These are the parts im looking at as well, have you got yet? if so what is your review of it?
    2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit! (FAMILY CAR)
    2014 F30 328I (ME CAR)
    2011 E46 330CI (SOLD)
  3. #23
    Feb 2015
    Sydney, Australia
    Quote Originally Posted by Safferbogun View Post
    Man I want that that R line body kit, anyone know where to buy these for the 2012 models?
    As Tigger73 said is much cheaper to get it as factory but otherwise could have got the ABT kit as an option.
  4. #24
    Quote Originally Posted by Evilz View Post
    I actually prefer the R-line kit over the ABT. R-line looks OEM (because it is) whereas the ABT has always looked like a kit car with bolt on plastics.
    I have the flared guards on my 155 but they are the same grey plastic as all of the other lower trims. This lets you run wider/more aggressive offset wheels. I would only get them to keep yourself legal otherwise they will make stock wheels look like they are running a long way in-board.
    Oct 2014
    Hey TIGR,
    Yep!
    Got the Supaloy's and the HP sway bars fitted last week.
    My verdict...
    cornering = brilliant (especially whilst accelerating in the corner, or out of a round-about etc)
    The steering generally is a heck more responsive.
    Are they worth the total cost? Sways - $475 + 475 + LCA's $750 + Labour etc $1900-ish
    I think it makes the Tiguan feel like it should.. I always felt like the steering and a bit too much of a sponge feel to it, but that's just my opinion.
    I think it's well worth the investment if you 'drive' the Tig - which if you've gone to Stage II - one would assume
    Just makes handling that 2 Tonne baby a much simpler and enjoyable task.
    From your sig block Evilz it looks like weve got a pretty similar setup, would like to know what you think of the GFB DV+ and what have you used the ABT kit for? (i'll go looking for your build thread now)
    TIGR
    2017 162TSI R-Line Tiguan -
    Tungsten Silver | DAP | APR Stage 1 Build thread: https://goo.gl/YNgixR
    2015 155TSI R-Line Tiguan
    Build thread: https://goo.gl/sEqISR
  6. #26
    Oct 2014
    and some pics (with the phone) sorry...
    Attached Thumbnails Attached Thumbnails TIGR's 2015 Tiguan 155TSI R-Line (Reflex Silver) - Build Thread-img_0390-jpg   TIGR's 2015 Tiguan 155TSI R-Line (Reflex Silver) - Build Thread-img_0391-jpg
    TIGR
  7. #27
    May 2012
    Can i have a sit in your Tig? Thinking to do the sway bar too, but only doing the rear not front
    Car:
    2015 Tiguan 155 R-Line (Daily) APR Stage 1 / 2011 (Track Weapon) Banned from Happy Laps
    Ex Car:
    2015 Audi S1 - Stock ish. . . . . . / 2012 ABARTH 500 - Black with 300hp
  8. #28
    Oct 2014
    Quote Originally Posted by syhm1984 View Post
    Unfortunately I'm down in Canberra (with the car) at the moment. But if you're down this way ... Sure!
    TIGR
  9. #29
    Feb 2015
    Sydney, Australia
    Hey TIGR,
    Form your earlier post "Does anyone get a 'chirp' or what sounds like a quiet beep when accelerating hard.. (like foot flat)?" I did experience the same noticeable "Chirp" sound as well. My best guesses is, it could be the stock engine mount is too soft. Given that the ECU and DSG been tuned for more responsive and output. I was actually looking into getting the HP engine mount first then the sway bar and lower control arms. Do you still have that Chrip sound when u foot flat on the accelerator?
    Indeed, we do have a very similar setup! lol As i believe that would be the best way to do so, given that i have a 5 months old baby at home now, the "Me time" become very precious and extremely limited.
    GFB DV+, in my opinion is surely a more substantial item than than the stock one. Other than that it have a better acoustic respond on the throttle, but don't think it does much on the performance. This is the first thing i installed together with the APR intake kit and i couldn't notice much of a different.
    With the APR intake kit, i did find that its extremely hard to fit in and screw on the 90 degree plate to secure the air-box. I think its because i also had the front bracket on for the connection between the air-box to the front panel. At the end i didn't put it on and it's actually pretty secured anyway. Did you come across the same issue as well?
    The ABT kit is just there to make it seem more sportier for me , given that the Tig R can only have the front grill and exhaust (without rear skirt) installed. In performance wise, the quad exhaust is 76 mm in diameter and it does make the engine feel much smoother with the breathing on low end and spool up faster in respond on high end. Also it does give it a great acoustic performance sound.
    The only think i highly recommend would be LED door warning light to be installed. For me it does make it much safer for the family to come out of the car in the dark. Plus it doesn't take long to install and wire it up, and of course you will need to activate it with VCDS.
    Lastly, did you end up installing the APR turbo muffler delete? I'm very curious if it actually does much of a different in the performance wise......
  10. #30
    Oct 2014
    Yes, I still get the chirp when i'm foot flat. I'll ask about the mounts.
    Thanks for the info re:ABT kit, im assuming you've bought the Rear Skirt Set and the Exhaust? Im just looking at the ABT website and most of the kit options look similar to the R-Line stuff anyway? Keen to know which pieces you've got, and what they look like
    I havent installed the turbo muffler delete, mainly because im looking at going K04
    TIGR
