Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 109
Thread: Tigger73's 155TSI
  1. #71
    How exciting.....I look forward to your "after" dyno..... Also if you get a chance can you vbox your 0-100km/h before and after with launch control ?
  2. #72
    I'll look to get some before/after runs with a GPS based timer. I don't have a v-box but do have access to a g-tec which is a very similar device with 10Hz GPS chip. I have found this is quite repeatable so even if it's not 100% accurate (i.e missed lead-in), it does give very consistent reading so the before/after comparison is still valid.
    Awesome, I've got a gtech as well and it's reasonably accurate... It's hard to find a perfectly level strip for a run, unless it's a closed circuit strip...but as you say you can measure relative improvement in similar conditions.
  4. #74
    I've got a stretch of "test road" that's pretty flat and only 20 minutes drive away. It's in a 110km/hr zone so I can do 0-100's legally.
    Arrawarra
    There's a strong possibility that there will be an "after" dyno result in the not too distant future
    Is Mrs tigger73 as excited as you are about this?
  6. #76
    Mrs tigger73 has been complaining that it doesn't go as well as the other one used to and that the gearbox doesn't shift as well... So looks like I might have to invest in some DSG software as well
    OK quick update. Had the car tuned and run at the recent dyno day in Adelaide.
    A nice 24kwaw gain and it's noticeably quicker.
    As an interesting note my 125TSI stage 2 made the same power figure on the same dyno.
    Dec 2013
    Nice! So was this a gtech? Apr tune now on sale and am really Keen to jump on this
    Sent from my GT-I9506 using Tapatalk
  9. #79
    Tune is RD Technik stage 1. It's a nice linear tune. I've had APR on the previous car and it tends to be punchier down low but fall off at the top end. The RDT tune just pulls all the way to redline. It feels more factory but just stronger and freer running. I didn't get an overlay done but I'll plot the before and after onto the same sheet.
    Yes the timer I've used is a G-tech unit. It belongs to another forum member.
    Dec 2013
    Interesting! Will have to find out of they're available in syd to compare prices
