A couple of bits that are (hopefully) going to make it onto the car this weekend:
Also thinking about getting a new DV+ from GFB...
2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
Naresh:
I really dig your wheels + arch set up. Make the Tiguan looks chunky and substantial. Do you mind sharing the offset +width of your wheels and what mm spacer you are using? Any rubbing problem?
Sorry Tigger73 for hijacking your thread
2011 Tiguan 125TSI - SOLD
2014 Race Blue Octavia RS 162TSI Combi
Check out my leather work ----> http://pedsnro.blogspot.com/
If the suspension setup is the same as the Golf's - the rear springs will take about 5-10mins each. The fronts are a bitch though.
The DV+ is a good little product - eliminates the problematic pieces from the stock DV but retains the solenoid and electronically controlled component. Mine is working well.
Sorry for the slight hijak, I just wanted to answer the questions above. Also, to confirm (without sounding arrogant) my car is a genuine R Line model, not just a bodykit.
My current wheels are 19x8.5 et 32 with 15mm spacers all round. No rubbing problems at all. The only time I got a few instances of arch scraping the tyres over severe bumps was a motorway run a couple of months ago, but the car had a full boot, and there were 5 of us in the car which included 3 back seat passengers each averaging 15 stone in weight. That was a VERY rare journey with the out-laws - something that won't get repeated again in a LOOOOOOOOOONG time!
Cheers for the info mate, appreciate that. I'm looking at 19 inch wheels with 9.5 width with blank offset, they can basically machine the wheels to have offset from et15 - 45. Probably best getting the arch extension first then play around with the offset later. Your stance will be the benchmark .
