Page 92 of 101 FirstFirst ... 42829091929394 ... LastLast
Results 911 to 920 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #911
    Jun 2013
    I have them from the factory, looks like another difference between mk1 and mk2.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  2. #912
    Tigger73's VW Tiguan 125 TSI Build Thread
    Quote Originally Posted by Ramee View Post
    The 125/132TSI gets the plastic covers and the 147/155TSI gets the chrome bag hooks. Crazy thing is that the cost difference is probably not that much especially when you factor in the extra tooling, engineering, parts inventory, production line complexity, etc.
    The one thing it does do us give some model differentiation but who would have thought that someone would pay the extra $7k to upgrade from the base model for a couple of $38 bag hooks.
    I have missed bag hooks (had them in previous cars). I generally put a single bag of shopping in the rear footwell to stop it sliding around but now I have some nice shiny new bag hooks to use instead
    Nov 2007
    My 09 125TSI had them from the factory ........ Luck of the draw I suppose
  4. #914
    Minor maintenace interval today - changed the oil, filter and sump plug.
    Is it just me or does the engine seem to run smoother with fresh oil?
    Jun 2013
    Haha.. Yes I change my Tig's engine oil every 7500 km with Motul Specific oil and every time I feel car runs smooth after oil change. It even runs better when I washed it too . My motto is love your car and it will love you right back
    Anyway I think if you change oil like 15000 k and car is bit older, you may feel a bigger difference.
  6. #916
    Erskineville, NSW
    Nope. I reckon they run rough for the first 500-1000km. Oil needs to be broken-in too.
  7. #917
    Arrawarra
    This year i've put in 2 new batches of Fuchs Titan GT1 etc & both times the car has not only appeared to idle smoother, but also run at around 3 degrees cooler than 8 - 10 thousand K old oil.
  8. #918
    Most of you have probably seen my other post about faulty parker lights: Intermittent Parker lights - faulty connectors???
    So after a bit of investigation and intermittent bulb out warnings on the dash I've made the major investment of $10.99 at Autobahn for a set of 2 Navra Ultra Blues. There was the Navras or some Phillips Super White 6000k - probably should have got these as the Navra ones are quite blue (and not that bright).
    Here's a couple of photos. First is with headlights on:
    Tigger73's 125TSI Tiguan Build Thread-004-jpg
    Just parkers:
    Tigger73's 125TSI Tiguan Build Thread-007-jpg
    Given the bulbs are cheap I may look at changing these out for something a little less blue and possibly a little brighter at some stage. May even try my luck with some error-free LEDs
    Sep 2011
    Townsville, Nth Qld
    DON'T DO IT - am yet to find a socalled error free LED for the park lights that is actually error free and given what a PITA it is to get them through the hole in headlight housing I don't think it's really worth it. I would put ordinary globes back in if I could but managed to mangle the holder a bit when trying to get one of earlier LED's back out again and now ordinary one too loose.....
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  10. #920
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by MGV View Post
    Will be putting this to the test myself this weekend - scored some of the Fuchs cheap through work and am going to change it on the weekend. Hoping it does drop the temp a few degrees as one thing I've noticed with tune is that it doesn't take much for the temp to climb in short order. Haven't got above 114° and I know these engines and the oil are meant to run that hot but still scares me a bit....
