My first mod (starting small) turned out to be not that successful (epic fail).
We liked the look of the 147 with chrome window trims so decided to get some aftermarket chrome trims to put on instead.
All was going well until we found out that the trims for the rear passenger doors were too long!
After a bit of further investigation I found out that these trims were designed to fit to the Chinese LWB Tiguan which has been stretched 50mm through the rear door to give more legroom in the rear seats.
So first mod ended up with sending the kit back and getting a refund.
I then installed a set of Whispbar Prorack roof racks.
Pulled off my front bumper and ran wire mesh through the upper and lower grille to stop any insects making a mess of the intercooler and a/c condenser.
I also debadged the boot as there was way too much stuff happening there... and then played around with what I might put back on
Plus installed a smoked 3rd brake light.
Before:
After:
Installed a stubby custom stainless antenna:
And finally black plasti-dipped the exterior lower plastics.
Blacked out the reflectors.... took the plasti-dip off the reverse lights before I drove it though
Plasti-dipped straight over the reverse park sensors without an issue.
This photo is when I'd completed half the car and you can see the contrast in this shot between the stock grey (on the front splitter) vs the rest of the trims along the side which have been plasti-dipped.
