Page 13 of 101 FirstFirst ... 311121314152363 ... LastLast
Results 121 to 130 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #121
    Sep 2011
    Townsville, Nth Qld
    Hi,
    has anyone tried the "Auto-Rain Closing" function? When I go in to "Diagnostics" it doesn't come up.
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  2. #122
    Quote Originally Posted by Tiggy1 View Post
    Hi,
    I'm not sure but I think that feature may only be for the sunroof. Like to close it when you've left it open and some rain comes along... but don't know how that could work without running some of the electronics modules while the car is switched off.
    I may have to do some further investigation on this one.
    Sep 2011
    Townsville, Nth Qld
    Hi mate,
    no biggie - just thought it would be handy. Could make sense that it has to have sunroof because when I went in to diagnostics it came up with "Identifying Available Functions" first time around, so presumably not an option on mine?! Is there a special procedure I might be missing for turning the screen display off too? Turn it off using menu, but then it's back again whenever I re-start the car
  4. #124
    Hi mate,
    I've been able to replicate both these issues in my Tig so I've raised this as an issue on the auto-polar forum
    Oct 2011
    Desvejk,
    Could you repost the picture? Doesn't seem to be working and would love to see the setup. I've had my car 6 months and had two flats already, and the space saver is a right royal pain. The speed rating of 80km/h is severe inconvenience when you need to get around and use the freeway.
    MY12 155TSI TIGUAN - Comfort Pack, Beige Leather, Sat Nav, Bi-Xenons, 18" New York Alloys, Park Assist 2.
  6. #126
    Dec 2010
    Brisbane, Queensland
    Thanks for sharing the photo's, I'm now on the hunt for a spare full-size tyre for 'the Quan'! It's a lack of a full-size tyre that has played on my mind wheneverwe decide 'not' to venture too far off the beaten track. cheers
  7. #127
    Dec 2010
    PS. Neat job!
  8. #128
    Sep 2011
    Townsville, Nth Qld
    Thanks, appreciate it
    I have also noticed looking at version info that even though it is latest version, it has "rd" suffix for "Red Dot", rather than "wd" for "Wite Dot" (which I have). Thought I'd selected the right one when downloading, but will keep an eye on the forum and check it again once I've downloaded the next update.
  9. #129
    Mackay QLD
    Auto rain closing of windows should work without a sunroof installed. It only requires the sensor on the windscreen. I managed to activate it with no issues via VCDS. Maybe it did not pick up the sub module in the main BCM module 9 when you did the initial diagnostics scan?
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
  10. #130
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by Bambazonke View Post
    Hi mate, thanks for that - good to know. Will try again after I do next update to Auto-Polar.
