Quote Originally Posted by Ramee View Post
Hi Tigger, what is your 0 100 value from APR and Vezu, I am sure if you did not launch the car it will not be very good value. Also I heard even though people say 125 , 147, 155 all same engines I heard there are considerable differences in performance when under tune to get same power levels.
non-launch 0-100 times have been relatively consistent - around 7.1-7.2sec. I ran a 7.2sec with APR file today on a 30degC day.
I have done a couple of launches with my "old" Viezu file and got 6.2sec which is quite a way from the mid 5's most people with APR tunes are achieving.
125TSI should be tuneable to the same point as 147/155TSI as hardware is identical. However it will depend if the tuners have done the work to develop the 125TSI files to the same point.
Would be interested to hear times from 125/132TSI with APR (both stage 1 and stage 2). Obviously there's also going to be some variation in terms of timing equipment etc that people use also. I've done mine using my autopolar FIS+.
