looking good
also seems being the guinea pig was a good move too
looking good
Just a quick note to confirm that AutoPolar FIS+ Advanced unit I installed on the weekend does in fact support dipping the passenger side mirror when selecting revese gear.
Had a quick play around in the car at lunch and got it working.
I'll have to post a video/instructions of it later, but you can set the mirror to tilt down when revese gear is selected.
Short video off my phone showing set-up of mirror dipping feature of AutoPolar FIS+ Advanced...
For any Tig owners thinking of adding this to your car (I'm aware of a couple of guys with units but not yet installed), here's the link to the installation thread here: FIS+ Installation in 2011 Tiguan 125TSI
It took me about 4 hours hunting around under the steering wheel / through the firewall to finally locate the CANBUS gateway connector behind the glovebox.
It's a relatively simple install - remove glovebox, disconnect battery, connect up FIS+, re-install glovebox. Should take half an hour or so at moderate pace.
The unit allows you to read a lot more diagnostic information - boost/fuel pressure, engine/intake/exhaust temps, remaining litres, accurate speed (unaltered), engine RPM and a heap more. 4 parameters per screen and you can configure up to 16 screens of info if you choose.
It also allows you access to a number of other features that can be enabled through VCDS like changing the number of indicator flashes, locking at 20km/hr and a few other features that I've yet to explore.
Hi mate,
looks like a top little gadget - have to seriously consider getting one
One question though, does it give same functionality to be able to change settings that VAGCOM does? I haven't got VAGCOM, but just want to make sure I can set up things like the mirror dipping function without it.
Found this link which answered the question...
Autopolar Official Web site
Obviously (as it's plugged into the Comfort/Convenience Module) it allows you to make some mods there, which is really all I'm after.
Will PM you re getting one.
2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
Yes it does some of the VCDS functions/features which are implemented via selectable menus through the MFD.
FUNCTIONS AVAILABLE
[+] TV-Free function to see video in motion
[+] Battery drain fix for vehicles equipped with RNS-510 and old gateways before index "K"
[+] Parktronic OPS emulation function (see Parktronic screen in RNS510 with Parktronic PDC ecu) (only available with Skoda vehicles)
[+] Confort blinkers configurables from 3 to 10 blinks
[+] Mirror lowering function (passenger mirror goes down to a configured position when engage reverse gear)
[+] Add BT Hands free compatibility with White dot Hands free units (Can works with all models of BT for white dot cars up to this date)
[+] Activation / deactivation of RNS-510 hidden menu
[+] Basic functions availables with diagnostics cables:
1 - Adjust sensibility percentage of automatic wiper
2 - Adjust sensibility percentage of automatic lights
3 - Activation/Deactivation Daytime running lights
4 - Activation/Deactivation cornering lights
5 - Activation/Deactivation american lights
6 - Activation/Deactivation cornering lights
7 - Activation/Deactivation warning lights (with blinkers)
8 - Activation/Deactivation of second rear fog light
9 - Activation/Deactivation windows automatic rain closing
10 - Activation/Deactivation automatic closing at 20 Kmh
11 - Activation/Deactivation one touch closing
Though there's a lot of things in VCDS that aren't possible/implemented in FIS+. Things like clearing faults, scanning hardware and running logs - so VCDS still has it's place.
The FIS+ unit has ability to display a lot of the engine parameters direct into MFD which is neat. Here's the list for my Tig 125TSI:
Km/h
Out ˚C
RPM
Batt. V.
Fuel Lit.
Oil ˚C
Amb C
Intake ˚C
Coolant ˚C
Motor C
Radiator C
Boost PSI
Atm. PSI
Fuel PSI
F. rail PSI
Load %
M.A.F.
Pedal 1
Pedal 2
Valve 1
Valve 2
Tprq. Nm
Power CV
Oil level
Inj. Tim.
A. BTDC?
Mis. 1
Mis. 2
Mis. 3
Mis. 4
D.1KW
D.2KW
D.3KW
D.4KW
Exh. C
Lambda
N75 %
Side G
Though not sure why I need Side G in the Tig... as I really don't corner that hard
Speak for yourself
Ordered - thanks for all the help & info.
Now that I have this new toy, just wondering whether we can compare some stats.
Boost PSI: -7 to -1
Torque Nm: up to 320
Curious what other Tigs are reading (both stock and flashed)?
But back to topic ... can't seem to get automatic mode to work at all for mirror dipping.
Also even manual mode resets itself after a while.
I assume the configuration once saved is supposed to be saved down for good?
MY11 Tiguan 147TSI (SOLD)
