Page 76 of 101 FirstFirst ... 2666747576777886 ... LastLast
Results 751 to 760 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #751
    Jun 2009
    Definitely interested to hear the results of the dyno day.
    Is it an AWD capable dyno?
  2. #752
    Arrawarra
    Be interesting to find out what the car is putting out now with the new S3 intercooler installed. I'm guessing it'll be in the 150-160kwaw area.
    When it comes to measuring power/torque, is there a factor that converts from crank to wheels & vice versa, or are manufacturers figures (& tuners) actually measured with some sort of dynamometer attached the engine?
  3. #753
    Quote Originally Posted by team_v View Post
    Yes it's an AWD dyno so no disengaging the tailshaft/rear diff. Good thing is it's the same dyno I've been running on so hopefully I can get some good comparative data from previous runs as long as the ambient conditions are going to be similar.
    Quote Originally Posted by MGV View Post
    They connect up to the OBD port under the dash and take the engine RPM and other engine parameters from there. The figures that you get are a kwaw figure (calculated from the dyno rollers) and not a crank figure. You have to take off the drive-line losses to work out what the crank figure would be.
    Unfortunately I don't have a "stock" dyno result so I'm not sure what the % driveline loss is for the Tig. Though I know that the actual engine output is likely higher than the "advertised" 125kW.
    My previous dyno figures were a little disappointing when you compare it to other cars of similar power output. However now that I have the S3 intercooler installed I think it should be back to where I'd expected it to be. Not that the intercooler makes any power in itself but I'm convinced the old stock one was sapping power.
    Erskineville, NSW
    manufacturers quote power "at the flywheel" measured directly using an engine dynomometer not a rolling road. Conversion from kwATW to kwATF or vice-versa is at best an educated guess due to all the variables between flywheel & tyres (including tyre size & pressure). Then the variables between dynomometer setup, operator, brand, weather conditions, etc.
  5. #755
    From our own dyno measuring in house here (where we are doing our best to measure Engine power - not wheel), the DQ500 transmission pulls another 8 - 10% out of the motor by the time it gets to the front hubs when directly compared to the DQ 250 in the Golf GTI & Golf R.
    So mod per mod - at the wheels or hubs, you will never hit the same as the small gearbox brothers.
  6. #756
    ...but then on the positive side we hopefully won't destroy our gearbox either.
    On that front I'm interested to find out what modifications you've made to the DQ500 DSG in your Stage 3 Tig (if any). And at what point you'd recommend upgrading the internals.
    Jun 2009
    That is interesting to know.
    I have heard 20% loss or so for the 4motion system.
    Still, i would rather the DQ500 than the DQ200/250.
  8. #758
    I agree - the clutches are so much bigger - its an awesome upgrade from the poor little DQ 250. Our Tiguan, The K04 Tiguans & TTRS's are all holding up really well - all with stock clutches & our DSG software.
  9. #759
    Feb 2013
    Perth, WA
    I'm still puzzled as to why they don't put the DQ500 DSG into the new GTI or at least the R. Unless it's cost related. I thought it might be a little bigger and not fit, but the TTRS and RS3 blew that argument out the window.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  10. #760
    Nov 2009
    Quote Originally Posted by Wynnston View Post
    My guess is it's deemed overkill (or, rather, overly expensive), as neither the GTI nor the R require it from a torque perspective.
